Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Drum will not move
First of all my wt540 AQUARIUS HOTPOINT MACHINE,was making a very loud noise when on spin,like banging against something,now the drum will not move. please help.
  • Hotpoint Master
  • 3,463 Answers
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Noise from drum
This is difficult to work out as there are so many different symptoms. Here are my thoughts -
Dust from carbon rushes is black. Grey dust usually comes from a loose concrete weight. Loose tub weights are rare on this model but they cause a loud knocking noise which is often worse when the washing machine is revving up to spin and dying down from a spin (suspension problems are also often worse at this safe too). It's not normally a metallic sound though.
If the noise is coming from the motor banging against the sides of the machine then it will make the machine move when it happens. The whole machine may jump or move to one side. The motor often thumps the side of the washing machine on Hotpoint washers where the motor is fitted at the top of the tub and over to the right hand side. This is a daft place to fit a motor and only .I think they've eventually stopped now though.
It is normal to be able to push the drum to the side so that the motor hits the casing. If the suspension has gone, the tub should be twisted and leaning to one side more than the other or it just could be very loose. It's difficult to check suspension if you don't know how it should feel.
If the noise is coming from the inner drum hitting the heating element or throwing an object like a £1 coin (trapped between the inner drum and the outer tub) around, then the washing machine will be stable but the noise would still be a horrible metallic knocking. This is one cause I suspect.
Thank you for contacting Fixya.com
Aug 30, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Hi,i have a hotpoint aquarius wf340.which makes a very loud banging noise every time it spins,it works fine otherwise!
I had the same issue with a similar machine. Need to replace the spindle assembly (or otherwise make sure) that the belt is tight. Try replacing belt first.
Make sure machine is level. test it by putting some stuffed sockes in the machine, let them get thrown around. Listen for the banging noise, apart from the soft socks hitting the tumbler.
Aug 08, 2009 | Hotpoint Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Belt has come off - how do i put in back?
OPEN THE TOP AND THE BACK PANEL.
AND LOSEN MOTOR HINGE AND YOU WILL BE ABLE TO PUT A new BELT ON
Jun 06, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
942 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
