Question about Canon Pixma MP800 All-In-One InkJet Printer
PGI5BK Ink tank not recognized on MP600
Prblem occurred suddenly. Working fine one day (3 months actually), failure the next, for no apparent reason.
Printer wont work because original ink tank (3 months old) isn't recognised !!! Release and reseat - red light on..........until printhead returns to normal rest position, then light goes off and U150 message returns.
Repeated many times. Red light on when reseated in when printhead returns to normal rest position. Will a new ink tank solve problem??? If so for how long??? Is it a printhead problem???
  • 1 more comment
  • Anonymous Apr 29, 2009
    I have a similar problem. All of a sudden none of the print heads where recognized. No warning lights and an error message indicating print heads not recognized. Recycling the machine on and off did not fix it. Removal and re-installation of the print heads did not work.
  • Anonymous Mar 17, 2014
    I change printhead with NEW original item, but it don't works, no ink on paper.
    can you help me?
  • Anonymous Mar 23, 2014
    I bought a new printhead for my pixma ip90 printer.
    I correctly install it but it doesn't work : ink tanks are full, the printhead in unclogged, inks free come out but any ink is blowed on paper sheet.
    The some problem I had with old printhead.
I had the same problem. The problem also manifested itself by not being able to automatically align the print head. I reset the print head. Problem solved.
Posted on Dec 11, 2007
  • 274 Answers
You say the "original" is 3 months old? You are out of ink. Replace the cartridge. Even when there is still a little ink in the "tank" it reports back to the printer as empty. And yes it will go through all its checks and still show empty. They don't last forever even if you don't use the printer. The ink evaporates out over time.
Posted on Nov 22, 2007
Error code U150 The following ink tank cannot be recognized
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
Dec 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
U043 (Applicable ink tank
cannot be recognized.
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have had the mp600 for 3 years - worked fine on a couple of different pcs. I switched to a mac and encountered 2 issues - scanner stopped working and above problem of no black ink. The newest driver (just google mp600 driver) fixed the scanner issue. The ink issue has a work around - select non plain paper in the media quality tab, instead use any photo paper setting. Finding this area in a mac can be tricky - in the mini print options window you have to click the small chubby arrow and you will then be given a list of options including quality and media. Presto, black ink returns but probably uses more ink and takes longer to print. I have not found a more elegant solution as you have to select this non default paper option every time.
Apr 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error messages: U150 + Ink tank errors have occured
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Jul 12, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
U150 error?
My dad is having this same problem and has been for the last 5 months. It's not from the printer being new it's a defect in the engineering of the printer cartridge older. The yellow cartridge (being the middle) doesn't snugly fit and so it wiggles around losing it's connection with the printer. I fixed this by taking making tape and taping around the base of the cartridge. It's a tight fit and it doesn't disconnect itself ever. Hope this helps!
Sep 23, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP800 All-In-One InkJet Printer Logo
417 people viewed this question
old marine
old marine
