Question about Hoover Vacuums
Just took the hoover fh51000nc carpet cleaner out of the box and hande release doesn't hold it in upright position.
    Top Expert:
  • Hoover Master
  • 43,113 Answers
The release probably is defective.
Posted on Apr 08, 2017
Testimonial: "no kidding"
The foot bar is going up instead of staying on carpet and will not hoover carpets
Hi there, it's Jack at Dyson.
When you stand your DC24 upright after use, the cleaner head is held in place by the stabiliser mechanism. Unfortunately it sounds like the stabiliser isn't releasing correctly when you recline the machine into the vacuuming position.
We'd appreciate the chance to take some further details about this issue, and to help you resolve it. When you have your DC24 to hand, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you. If a repair or a replacement part is needed, we can also confirm if your machine is still covered by its Dyson parts and labour guarantee.
Feb 23, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Why does The beater bar on my hoover continue to run in the upright position?
Hi there! Some vacuums do not come with the feature that automatically shuts the brushes off when in the upright position.. If your unit is like this, be sure to put the vacuum on the highest setting when using the hose. Also, because the brush-roll continues to spin, avoid tipping cleaner or setting it on furniture, fringed area rugs, or carpeted stairs during tool use. Hope this was helpful!
Jul 21, 2014 | Hoover Vacuums
Why is thecleaner not coming out of carpet cleaner
You have to continually hold the trigger to release the cleaning solution. If you don't hold the trigger closed then you are running the vacuum in carpet drying mode. http://hoover.com/file/610/
May 25, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Dont have a manual how do u connect the hose to it
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
May 05, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Replace accessory hose
i There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
Raise carpet cleaner handle to upright
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 15, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Model #5880-900 Hoover spin brush carpet cleaner
i WAS LOOKING AROUND FOR A SERVICE MANUAL FOR MY F5897900 CARPET CLEANER AND I SAW SOME THING ABOUT HAVING TO "PRIME" THE PUMP. YOU PPARENTLY TAKE THE TOOL HOSE AND HOLD YOUR HAND OVER IT FOR ABOUT 15 SECONDS. THIS MAY OR MAY NOT WORK.
ANYBODY KNOW WHERE I CAN FIND A SERVICE MANUAL FOR A HOOVER CARPET CLEANER? SEEMS TO BE A VERY CLOSELEY GUARDED SECRET.
RON
Sep 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Hoover Steamvac F5892-900 leaving lines on carpet, does not seem to spray
Is the cleaner sucking up the water like it should? If not , check that the filter on the inside of the lid has a 1/4 in. gap between the filter and the top of the lid. Either that or the water isn't completely being shut off when you release the trigger, in whcih case you would probably have to take it in for service.
Jan 31, 2008 | Hoover F5892-900 SteamVac Upright Vacuum
Vacuums Logo
35 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
