Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
5914-900 not sucking up the solution
Used only once
    Problem Solver:
  • 8 Answers
There's a leak somewhere! This also happened to me. Take both tanks off and clean them thoroughly. The rubber seal on the bottom of the water receptacle tank has to be seated firmly and the tank locked down with the little arms (one on each side). Pet hair clogs this model and has to be removed after each use. Look for debris, etc that may be preventing the tank from sealing properly.
Posted on Jul 30, 2009
The cleaner is not sucking up the water from the carpet
There should be a filter. If it's clogged or old, water will not flow through it properly. Meaning... Your machine will not suck the water up, once you've made a big mess on your carpet.
Good luck and Merry Christmas, Bill
Dec 19, 2014 | Vacuums
Sucking and blowing sound went switched on
Hi Steve, it's Jack at Dyson.
From what you've described, it sounds as if the suction relief valve may be activating. This opens to let more airflow into the motor if the machine is used when blocked, or if the washable filters are very overdue for a clean.
In normal use, both filters should be washed using cold water without detergent, at least once a month. Allow at least 24 hours for both filters to dry completely before replacing them in the machine.
To check your DC24's cleaner head and airways for blockages, please follow each of the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc24new/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usualdc24
If you'd like some further advice from our experts after giving these checks a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 30, 2014 | Dyson DC24 Ball All-Floors Upright Vacuum...
Not sucking strongly enough
Hi Neil, it's Jack at Dyson.
If your DC40 isn't picking up as well as it should be, it's likely there will be a blockage that you may have missed. The most effective way to check for this is to follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc40/dc40-multi-floor-complete/my-machine-is-not-working/machine-not-sucking-up-well/both-checks-checking-wand-and-hose-step-1
We'd also recommend washing both filters, which should be done at least once a month in normal use - the video attached should help. Use cold water without detergent, and allow at least 24 hours for them to dry before replacing them.
If you'd like some further help after you've given this a try, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 05, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Suck hoover
If the wire is underneath the unit it won\'t suck up the water. I did this once. Make sure it is flush with the floor.
Nov 11, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
No sucking when the handle is down
Hi Steven, it's Jack at Dyson.
If your machine isn't picking up from the cleaner head, this may be due to a blockage. The filter may also need a wash. To check for any obstructions, please follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc07/dc07-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
In normal use, DC07's filter needs to be washed at least once every 3-6 months, as shown in the video attached. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
If you do need any further advice after you've given this a try, please get in touch with us directly. You can reach our experts by calling 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 12, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
Using a Hoover Steamvac to clean my carpets. It works fine in some areas, but others it makes a clicking noise and stops sucking water. Once I turn the vacuum off and wait a few seconds, it clicks once...
1)clog in the hose or air/tank full you must , need replace or emptied,test the belt for broken or worn.
2) noises can be area motor , test for fan blade defective or broken
3) You must go http://hoover.com/support/video-instruction-guides/ for more detaisl about your machine.
God bless you
Jul 15, 2012 | Vacuums
HOW DO i GET THE WATER OUT OF THE CARPET ONCE IT'S CLEANED?
Do you have a shop vac . Take the bag out of the shop vac ,and **** up the water . When you are done open your windows and do not walk on the carpet for at least one hour . You want your carpets to dry with the pile standing up. Carpet rake is the best thing to use . Best of luck Ed.
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I sucked up a dusing cloth with my ducted vacuum cleaner and now it does not **** at all. Help can not afford a three hundred dollar bill. blocked
Turn off the power on the main vacuum unit. Then thread a plumber's snake or stiff small gauge wire from the outlet you were plugged into when the dust cloth got sucked up. With any luck, you'll be able to push it through a bit or with a small bend at the tip of the wire, you might catch hold of the rag and pull it out. You could also try sucking out the line with a shop vac by fitting it tightly into the outlet and turning on the vacuum.
hope it helps.
please rate this solution.
Thanks for using FixYa.
Feb 13, 2009 | Emerson Vacuums
No suction
if this is a 9400 series check and make sure the red flap in the lid of the dirty water tank is not closed.
Apr 02, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Kirby sentria
Hi There, The machine does not actually suck the suds up. Basically the machine lays the foam down which then crystalises and absorbs the dirt in the process. Once this has had around - 4-5 hours to dry then you vacuum up as normal taking the crystalised dirt away. You should really use the Genuine Kirby product as it's very good but you can also you any other DRY FOAM shampoo. Hope this helps Chris www.elidistribution.co.uk
Sep 22, 2007 | Vacuums
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
205 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
