Tut systems Expresso MDU Lite-LR. Lost password--need to set to factory defaults
  • 10 more comments
  • doug736 Jul 25, 2009
    Hello;
    I had tried both of these before. It just restarts the unit--the settings are not changed to factory defaults. I even tried holding reset for a minute--no luck.
    Any other ideas?
    Pushing the reset pinhole only restarts the unit. Even holding reset at power on does not return the unit to factory defaults.
    I suspect it's a more complicated solution--does anyone have experience with a Tut Systems Expresso MDU Lite-LR?
    Someone must know the "real" solution. The manual says to call customer support, but the company (Tut Systems) no longer exists.
  • doug736 Jul 26, 2009
    yes, but they don't support this product anymore. It was obsoleted before Motorola bought Tut
    So far the suggestions given are obvious & useless--does anyone really know about this product?
    Yep, I'm using the telnet console port. Apparently the designers of this really wanted it secure. The console still requires a password, which does not get reset by pressing the reset pinhole.
    I am using the console/telnet serial port, but it still requires a password.
    Does anyone know how to reset this thing to factory defaults (PS: reset alone doesn't do it.)
  • doug736 Jul 27, 2009
    Does anyone have experience with Tut Expresso MDU Lite?
    Yep, it's an 8 port line concentrator-Tut Systems part#810-04565-12. (I don't know why I'm in the router category)
    Need someone with experience with this product.
    Please, no more obvious answers. This one requires that you actually know this product.
    nope, guess again.
    Scholar:
  • 151 Answers
Because of crime and other things coming across a code for a radio in the car will not be easy on the internet e.t.c, the best thing you can do is take it down your local car retail or repair shop e.g. in england there is a place called halfords n they sell radio's e.t.c. for cars.
I hope this helps you out Regards
Posted on Jul 29, 2009
  • Laurence Reeves
    Laurence Reeves Jul 29, 2009
    Sorry, my comment had nothing to do with this, Ignore what i said
    Very sorry
    Have a nice day
    President:
  • 1,734 Answers
The factory default password setting is 0000. If you changed
it, and forgot it the unit will have to be returned to Motorola to be unlocked. This is not
covered under warranty.
NOTE: This parameter is not altered by the Factory parameter
(CONFIGURATIONS category).
Sorry for bad news.
Posted on Jul 28, 2009
    President:
  • 1,723 Answers
There's a small hole on the back you can fit a paper clip end into. This will reset it to factory default settings.
Posted on Jul 27, 2009
    Top Expert:
  • Computers & ... Master
  • 79,865 Answers
IT SHOULD BE OBVIOUS BY NOW THAT YOU ARE STUCK, THE COMPANY IS THE ONLY ONE THAT COULD SUPPLY THE NEEDED INFO, THEY ARE OUT OF BUSINESS, REPLACE THE UNIT.
  • yadayada
    yadayada Jul 27, 2009
  • yadayada
    nope guess again.
  • 11,896 Answers
Option 1
You can either find the little pin size hole in the back that is the reset. You need to hold this button down for 10 seconds.
Option 2
Leave unplugged for 1 hour
Option 3
Access your router via internet address bar 192.168.1.1
Username Admin
Password Admin
Change information and save it.
  • Nate Stansfield
    Nate Stansfield Jul 27, 2009
    www.proxim.cz/data/products/download/hsg%20manual.pdf
    This is a link to your complete manual.
  • 1,272 Answers
Could you please specify the exact model number for this device.
Expresso MDU Lite is not a rouer but a 8-Port Line Concentrator
  • Anand Gupta
    Anand Gupta Jul 27, 2009
    Honestly speaking, not aware of this product.
    Regards
    Anand
    President:
  • 2,923 Answers
You mentioned that you tried holding down the reset button while the power is not did not do any help, right? Please try this:
1. Hold down the reset button for 30 seconds while the device is ON.
2. After 30 seconds, unplug the power adapter from the MDU Lite without releasing the reset button.
3. Give another 30 seconds then put the power back in.
4. Release the reset button.
If this will not do any help, you need to open up the device and reset it by shorting the jumper. Refer to the user manual to see which jumper to short.
If you couldn't find which jumper, contact the manufacturer.
Have a great day!
Posted on Jul 26, 2009
  • 13,433 Answers
Is there a console port? serial cable connector? if you had the management software you might be able to connect over a serial cable into the machine to change the settings. You could probably try telnet into the com port.
serial port - http://www.computerhope.com/jargon/s/seriport.htm
you would connect it to your computer and use the management software or try telnet
serial cable - http://en.wikipedia.org/wiki/Serial_cable
as tut is gone, this may be somewhat difficult to figure out how to manage the machine over serial / com / console.
  • 341 Answers
Isn't Tut systems part of Motorola?
Posted on Jul 25, 2009
  • 1,555 Answers
This site tries brute force password recovery.
http://www.scribd.com/doc/3480160/100-000-words
This one will give you temporary passord
http://www1.shopping.com/xPP-concentrators_and_multiplexors-tut_system_expresso_mdu_concentrator_concentrators_multiplexers
www.thefreelibrary.com/2-Infinity.Com+and+Tut+Systems+to+Provide+Internet+Service+to+ATS...-a055823375
  • 19,396 Answers
There should be a pin hole switch at the back of the concentrator, to reset the unit to factory setting.
Try pushing the pinhole reset switch with a pencil for ten second. If that does not work , unplug the unit from power, and hold down the pinhole with a pencil while connecting power and starting the concentrator at the same time.
After resetting the concentrator you will have to enter again settings.
Posted on Jul 24, 2009
HOW TO UNLOCK MY WIRELESS ROUTER TL-WR740N
You should restore the Factory Defaults to get full access to the router. Be aware that all custom settings will be undone with this procedure.
This can be achieved this way:
* Choose menu "System Tools ? Factory Defaults", and you can restore the configurations of the Router to factory defaults on the following screen
* Click the Restore button to reset all configuration settings to their default values.
* The default User Name: admin
* The default Password: admin
* The default IP Address: 192.168.1.1
Aug 23, 2011 | AGPtek TPLink TLWR740N IEEE 80211bgn...
I have an WNR1000 and I have lost the password but have the disk. How do I reinstall?
On the back of the router there is a very small button something you would need to use a paperclip or other small object to push push and hold that button for a few seconds that will restore the factory default settings to the router. then admin should be the user id and leave the password blank to get into the router settings
Mar 23, 2011 | NetGear WGT624 Wireless Router
How can i recharge my internet modem
How do I check my credit on expreso modem and to recharge
Feb 18, 2011 | Tut Systems Expresso MDU ACLC-SDSL-2.3...
Lost password to router
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Feb 01, 2011 | Belkin F5D72344 Wireless G Router 54Mbps...
I forgot my Password for NETGear WGT624 Please help
or
hope this helps
Jan 17, 2011 | NetGear WGT624 Wireless Router
I FORGET MY PASSWORD TO MY NETGEAR WIRELESS ROUTER HOW, WHERE OR WHO DO I CONTACT/ CALL TO RECOVER IT?
or
hope this helps
Jan 07, 2011 | Computers & Internet
Need to find the password for my Netgear WPN824 router
or
hope this helps
Default Password for Proxim AP 4000 MRLR
The default password is should be "public" if it was factory defaulted.
Dec 04, 2010 | Proxim ORiNOCO AP-4000MR (8670-MR-LR)...
How to reset the Password n 3510-24T Nortel switch
Hi Try the following - it should go back to factory default settings
There can be times when you need to factory reset a switch. This process can be accomplished through the CLI but if you've lost the switch password you'll need to follow a special process. This process should work for any of the Ethernet Switches (450, 460, 470) and the Ethernet Routing Switches 2500 Series, 4500 Series, 5500 (5510, 5520, 5530) Series. There is a different process to recover lost passwords on the Ethernet Routing Switch 1600 and 8600. Please note that by factory resetting the switch you will loose all configuration settings. It will be as if it just arrived from the "factory".
Follow these steps:
1. Connect to the console port of the switch (9600,8,N,1)
2. Reboot the switch.
3. When the first line of the diagnostics tests is displayed, press CTRL-C. The system then displays a menu.
4. Select option "i" to factory default the switch.
5. Select option "a" to run the agent code.
Upon boot up, the switch will be in a factory default configuration
Jan 06, 2010 | Nortel Ethernet Routing Switch 3510-24T...
Computers & Internet Logo
859 people viewed this question
David Payne
David Payne
