Question about Vizio GV42L 42 in. LCD Television
White has turned pinkish
Faces have blue, pink circling. white backgrounds blur pink, blue, and some yellow. All white has a pinkish tint
    Problem Solver:
  • 10 Answers
Sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Posted on Aug 10, 2009
  •  Neil Gall
    Neil Gall Apr 17, 2012
    ONLY projection tv's need ANY type of alignment. Any flat panels (LCD/Plasma) DO NOT require any type of alignment as they are already aligned through their substrate at the assembly plant. It sounds to me like you have a GREEN sub-processor or driver issue.
Why does titanium white paint turn pink?
add drop of blue and this should solve the problem,
for future reference - what paint? aquarel? pastel? oil? acrylic? tempera?
solvent sometime can be a problem, if you use varnish - varnish naturally turns bit of yellow, sometime pinkish tint, but you need to check if solvents are compatible.
there is heaps of variables in paint mixes, you need to check purity of the pigment (rutile ore contamination's will tend to discolour pigment anything between brown and pink for example with the age), you need to check opacity of the paint (how transparent it is - background may cut through it and sublight it red), you need to check viscosity (light viscosity and dry pigment in wet on wet will "suck" paint from the background), all of these need to be check.
if you have more questions on the subject - you need to provide what medium you use and what is exactly effect.
hope this will help you - do not forget to vote...
Feb 20, 2015 | Crafts & Hobbies
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
Acer dlp 1120 show pinkish tint
for acer p1120 pinkish tint solved:
reset your lamp hours
do hard reset :
power off beamer
unplug power cord and press power at same time
replug power cord in beamer and press power button for 10 sec
now it should turn up normal again pink is gone
i called acer also with solution so they can also help you out if you dont get it done
Sep 11, 2013 | Acer P1120 3D Video Projector ACER
Pink horizontal lines on samsung plasma tc when white background
I have this same tv and have the same problem, anytime there is a white background there is this pinkinsh tint in the middle of the screen, easily seen during those Apple commercials.
Aug 13, 2012 | Samsung 3D Plasma TV PN58C8000YFXZA...
Background, e.g. or sky, or anything white are pink. what is the
Is this in all the SCN?
I'm sorry, but in this case there isn't much more to do than to Trade up. Since this model is no longer repaired due to spare parts shortage.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 03, 2009 | Kodak EasyShare CX7330 Digital Camera
Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
Oct 11, 2009 | Samsung HLN4365W 43" Rear Projection...
Yellowish tint on faces, shadows, gold backgrounds
Check the white balance setting of the camera. As you have a yellow cast, it could be because you are using it in Fluorescent (or Tubelight) setting. Changing this to Auto should solve this problem.
Jan 22, 2009 | Fuji FinePix S1000FD Digital Camera
Mercury cougar
Constant 12V+ Black/Orange Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Light Green Dimmer n/a Amplifier Remote Dark Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Pink/Light Green Left Rear (-) Tan/Yellow Right Rear (+) Pink/Light Blue Right Rear (-) Brown/Pink
Sep 28, 2008 | JVC AM FM CD DET FACE CAR STEREO
Greenish tint
Not sure if this is the solution, but I believe the color polarizer filters have been burned. I have a yellow haze circle on mine and I'm pretty sure that's the problem. In my case the blue filter is burned, leaving the red and green stronger yeilding a yellow blur.
Aug 27, 2008 | Epson - PowerLite S1+ Multimedia Projector
Vizio GV42L 42 in. LCD Television Logo
586 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
