My clarity ctvl37w2hdf turned off and wont turn back on took it to a repairer who said it was a problem with the power supply in the tv but could not get any parts can someone help. regards morgan
hardrocko
  • 1476 Answers
SOURCE: When it's turned on, the light on my monitor doesnt show any signal of power supply
I'm assuming that you mean the green indicator light is not on. This could be caused by a host of problems. Assuming that you know the AC receptacle is live by testing with a standard light the next step would be to unplug the unit and remove the back. Check the fuse for continuity. If the fuse is good you have a problem with the power supply or a short which is keeping the power supply from powering up. The most likely culprit is the Horizontal Output Transistor. Unless you are an electronic tech and know how to check this you probably need to take the unit to a shop for further diagnostics and repair.
Posted on Jun 22, 2006
SOURCE: Need Help big screen turns on thens goes off
The blinking light tells you what is wrong with the circuit. If it blinks 3 times it is the convergence amplifiler. I had this problem and tried to fix it myself and I don't think that I have it connected good enough. I know this is the problem with mine. I will let you know if this fixes that. Let me see what 5 blinking lites mean. I will tell you what each blink means from the repair manual, 1 blink is +140 circuit, 2 blinks is Low DC, 3 blinks is convergence, 4 blinks is HHS, 5 blinks is IC4011, 6 blinks is IC4018. I hope this helps. You can get a repair manual at servicemanuals.com it really helped me. I will let you know how my repair goes. I hope this helps. Rick
Posted on Dec 12, 2007
SOURCE: projection tv wont turn on
i had same problem after house power switched off 3 times in same day disconnected power left overnight worked ok i will still take tv for a service .
red light was blinking 10 times
Posted on Feb 24, 2008
MrBob84
  • 90 Answers
SOURCE: Power Supply repair
SHUT YOUR UNIT DOWN NOW.  We don't want further and more expensive repairs to be needed because of the threat of the domino effect to boards downline from this one, that not remedying this situation carries with it, every moment it has warmed up and is running, in this intermittent condition.
This is a problem that is very widespread on this series of unit, and I have been 100% successful in remedying it so far, both on location and by doing the repair op on boards sent to me from many parts of the continent, and returned by me ready to go.  This has been happening over and over and over again - many Pioneer Elite - and non-Elite - boards have been sent my way, with owners totally blitzed to have their sets up and running faithfully again, after the repair.
Please call me for details and leave me contact info for you, and also send me a request via email, at bob at imageperfection dot com.
I am not at home and can't reach for that stuff to email you, which I can do later once I'm home again later today.
Bob 510-278-4247
Posted on May 11, 2008
  • 50 Answers
SOURCE: Dell Inspiron 1000 notebook won't turn on
The motherboard is bad. This model had a fault where after a while the North Bidge heatsink would break off and short the motherboard distroying it. This problem is something to not fix, it is not worth it, cost more than it is worth.
Posted on Dec 07, 2008
Why wont my lg 50 plasma tv turn
Perhaps replace your power cord. Borrow power cord from repair shop. If it works it's the cord. Also if the TV is plugged into power bar make sure the power bar hasn't been inadvertently turned off.
Oct 07, 2015 | LG Televison & Video
How do i reset Clarity ctvl37w2hdf led tv or at least set the timer to off?
to reset the tv, hold the power button while you unplug the TV. Keep holding the power button for :15 seconds, then release it and turn the power back on. That should reset any timer.
Nov 25, 2014 | Hardware & Accessories
Sylvania LC320SLX 32 in. LCD TV wont turn on
There is short circuited component/s at its main power supply regulator board. Check and replace them. It is best to replace the circuit board as card bassis, rather than trying to repair it.
Jun 13, 2013 | Sylvania LC320SLX 32 in. LCD TV
When i turn off tv it wont go back on for hours
The most likely issue is your power supply is failing. Most likely issue that would cause this problem is bad capacitors on the power supply.
What happens in the above situation is:
After the Tv has been off for some time the electronics and capacitors are cool and supply the correct voltage so the TV turns on.
After using the TV the electronics heat up and the material in the capacitors expands causing the power supply to supply incorrect voltage. With the TV the power is flowing and is close enough to the correct values for the TV to stay on, after being shut off the TV will not turn back on because correct voltage is not present until the components cool down and the voltage at power on no longer engages the protection circuit.
Info on checking and testing power supply's
Info on finding and repairing bad. Damaged, leaking or swollen capacitors
Jun 07, 2012 | Hisense LHDN32V66AUS 32 in. LCD TV
Power supply
As a rule TV Techs will inspect the power supply first. I would certainly see if the fuses are good or bad. Simple?...well yes and no. If you should find a glass fuse and the clarity of the glass internally is clean, no problem.. Now..if the fuse is open and the clarity is clean inside....replacement will cure the TV problem.Repair is still possible. If the fuse is smoky and black internally...major problems, see a tech. If repairs are possible,(good fuse) next suspect a weak power supply and check all grounds, capacitors and resistors. Check voltages if possible. If the power supply is good...and the TV will not operate...could be the signal board. Just a few hints to get you started!
Nov 07, 2010 | Televison & Video
52'' Sony Bravia will not turn on
Its fixable problem like power supply board replacement will solve the problem.
Unplug tv from wall socket for couple of minutes, replug back in and turn it On.
If problem still exist then most likely power supply got fired and will be replaced, local tv repair shop will help you to replace power supply board.
Thanks.
May 02, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Samsung tv wont turn on stand by button just keeps clicking
To all who are having power supply issues: Samsung is now acknowledging a problem with faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem
Jan 04, 2010 | Samsung LE40M91B 40 in. LCD TV
No picture
My parents bought the same tv, TV ran fine for 2 years then started giving them problems. Blue light comes on then few seconds later turns to yellow. Turn tv off then back on it worked, until last week it would not turn on.
Took it to a repair shop they said it was a bad power supply and it will cost 50$ for this check up, as it turns out the total bill would be $650 minus the original $50 it would only cost you $600.
Needles to say i took the tv home with me. Since they were not going to use it i started looking at it took the back off, removed all heat shiels ect. Took my magnifing glass out and started looking at the power supply come to find out the part was made in China, it was missing a solder joint, pulled my old soldering gun out, five minutes later the tv came back to life.
i hope this helps.
JOHN
Oct 23, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Tv wont turn on
The power supply or high voltage circuits have failed, You will need to take it to a repair shop.
Feb 19, 2008 | Televison & Video
Televison & Video Logo
283 people viewed this question
Top Televison & Video Experts
Electro Med Services...
