Question about HP PSC 2175 All-In-One InkJet Printer
Printer will not copy
OK we ran out of black ink. So I had DH take out the empty black ink
cartridge (56) and he accidentally allowed the machine to run with I
think the empty cartridge spot open. The machine made a funny noise. We
went and got the new cartridge, installed it. Now it will print fine
from the computer and it will scan as well from the computer. BUT if I
try to just copy straight from the printer it constantly asks us to
press 'enter' so it can align the cartridges (which we have done many
times.) It will not just copy! Can you help us? Thank you. Sincerely,
Rosemarie
  • Rosie Posie Nov 28, 2007
    GReat! Thank you SOOO much! It worked! I cheaped out on buying a new color cartridge and pressed the setup button and then the options button and it worked great! Thanks again!
  • HP Master
  • 1,113 Answers
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Posted on Nov 21, 2007
  • Soulvisitor
    Soulvisitor Nov 28, 2007
    Great to hear it solved your "issue" with DH and the printer. Thanks for rating, so many don't bother to, and I enjoy knowing that I have helped someone overcome their problem
Have an HP Deskjet 3050 and just replaced a black ink cartridge 61 with a black ink cartridge 56. Got an error message that says: "Cartridge problem. At least one of the Cartridges has a problem." Have...
On the inside of the cartridge door is the number of the cartridge you must use in your printer. If you put in another number, the electronic chip on the cartridge will tell the printer what type it is and the printer does not want to work with the cartridge. In the chip the printer also keeps track about the uses of the ink.
If number 56 is allowed too, perhaps another cartridge is empty too.
I think you did remove the pink label from the cartridge before you inserted it. because that label will block the electronic connection between the cartridge and the printer.
The manual explains how you can see what cartridge is causing trouble. When the printer is connected to a computer you also can use the computer to find out.
Oct 29, 2013 | HP Office Equipment & Supplies
I have an Epson XP-202 printer which I use solely as a black and white copier. Accidentally I pressed the colour button for a copy which ( as the original colour cartridges are still in the machine) has...
Not sure about Epson but I had the same problem and the store where I buy my ink said that a lot of the printer companies require all the color cartridges with ink in them to work. My color use to disappear even if I just pushed black and they said that was the way they were made . They sell printers quite cheap but make their money on the ink. I got rid of mine and purchased a black only ink jet and it hardly uses any ink at all. Its a powder. You can copy many copies on eighty dollars worth of ink where the cartridges I went through several hundred dollars a year.
Jun 14, 2017 | Epson Office Equipment & Supplies
I want to use Black ink only but it will not print because the colors are empty. Do I need to replace all cartridges (LC61) for Brothers print, copy, fax machine. Thanks
If you don't want to replace the color cartridges, you can fool the printer instead. Sensors in the printer shine light through a thin area on the cartridges. The empty (or even just low, even though there may be plenty of ink still inside) cartridges allow the light to get through, the printer sees the empty cartridges, and it won't print anymore. You can cover this part of the cartridge with a piece of black electrical tape to block the light. Voila! No light gets through and the printer thinks you have full cartridges again. This site has pictures showing where to put the tape. I've used this trick on the printer we have here in our office and it works great.
Feb 11, 2011 | Office Equipment & Supplies
MFC-420CN refuses to recognize or use black ink
The print head is clogged.Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 25, 2009 | Brother MFC 420CN All-In-One InkJet...
My printer will not work if one of inks is out and will not have otion for black only
This is a known problem with this printer, functions such as fax and copy will also be unavailable if the ink is low.
The low ink alert will appear even though the cartridge is not empty.
Here is the solution:
The ink cartridge has a sensor on the bottom, between the nozzles.
cut a small piece of tape and tape over the sensor.
The printer will now think the cartridge is full.
This will allow you to use every function of the printer regardless of how much ink you have. The cartridge will truly be empty when your print outs come out blank.
Jun 28, 2009 | Brother Multi-Function Center MFC-240C...
Won't copy
there is a little window on the ink cartridge that if blocked the machine will think there is ink, i caution you however that if attempted it can cause serious damage to machine.
the little window should be on the end of cartridge that slides in first. if you look in the printer you should see the sensor bank that reads through the little window
Apr 29, 2009 | Office Equipment & Supplies
Machine does not recognize refilled office max cartridge (black)
sir,
try to clean the cartridge on the copper side with tissue with and alcohol maybe the contact points doesnt meet or the cartidge itself is already defective. try also use an empty good cartridge just to to determine wich cartridge is defective.
yours,
alecz
Apr 23, 2008 | HP PSC 950 All-In-One InkJet Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printing in black & white when color cartridge ran out
I had the same problem. Had no choice but to buy the colors I ran out to make the printer work. In order to avoid future problems and save on color inked I attempted to follow the steps of a previous posting, however, that did not work for me. This is what I had did. Print, select properties, advance, continue, check box - Black ink only. Remember when you decide to print in color you must reset your setting and take out the check from the - Black ink only.
Sep 08, 2007 | Epson Stylus CX6600 All-In-One InkJet...
HP PSC 2175 All-In-One InkJet Printer Logo
187 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
