Question about LG LFX25960 Bottom Freezer French Door Refrigerator
I've got the LFX25960ST model. The icemaker
I've got the LFX25960ST model. The icemaker jammed up with ''medium'' sized cubes and the cubes were stuck together at the top. I emptied the ice bin, but the metal arm was stuck in the ''up'' or raised position, so the icemaker won't make ice. I shut the icemaker off for 12 hours and the arm dropped back down and ''free-moving'' so I turned the icemaker back on, re-installed the ice bin, ice cubes set to ''medium''. 12 hours later, still no ice and the arm is stuck in the ''up'' position! I pretty sure that if the arm was down, the icemaker would make ice, meaning I don't think the problem is with other components. Any ideas?
  • 36 Answers
Its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Posted on Jul 24, 2009
How do i fix my whirlpool icemaker it seems that it gets stuck half way into icemaking and does not produce ice.the model is ed5hhaxv002 it is very frustrating i havce tried a blow dryer to heat the r
Your rubber tube is most likely not freezing up and therefore does not need to be heated but only you would know for certain. My experience with ice makes spans several different models but I've found the most common problem for me with no ice being produced is when the bar that shuts of the icemaker gets stuck in the up position because - ice cubes have frozen into a big clump, Ice cubes have jammed the bar by sticking between the ice tray and the bar, or the gear inside that rotates the ice cube tray is stripped in that area because of previous jams and needs to be replaced.
Dec 01, 2014 | Whirlpool Refrigerators
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How do you change the ice cube size on this model? I cannot locate the ice cube size button anywhere!?
Hello there
Normally
You can't change the shape. or the size of the ice that is produced s It's determined by the manufacturer of the ice maker. but if you have the adjustment feature on your icemaker than pull the front cover off of the icemaker ande their will be a round adjustment wheel with different letters along the side these represent the different sizes of the ice that can be produced
their should also be a diagram on the inside ov the cover that you just took off that will help explain the different settings ok
I hope that this is very helpfull for you.
Best regards Michael
Nov 05, 2009 | LG Refrigerators
Cube size adjustment location on lg refrigerator
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 29, 2009 | ASUS Eee PC 900 Notebook
The icemaker has stopped making ice after 2 years of functioning.
No I don't think electronic. But you may need to check the water control valve on back and pour tap water into ice maker to see if it cycles and dumps. Remove the wires on the water control valve and with an ohm meter check both coils. The resistance should be close to the same. Let me know, Sea Breeze
Jul 20, 2009 | LG LFX25960ST Stainless Steel French Door...
Icemaker does not work
Does your unit have the cube size selection button inside of the ice maker door , if so is it lit up, if so is it on a cube selection. If not that is the reason the ice maker is not working because even though the unit is on the cube selection has not been made. This should solve your problem.
Jul 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Icemaker stopped making ice.
make sure you can see the green light is on which means you have power. if its lit,press and hold the cube size button untill i/m starts to cycle if i/m runs but does fill then your water valve is bad, if i/m will not start then your i/m is at fault
Dec 13, 2008 | LG LFX25960ST Stainless Steel French Door...
Icemaker not making ice - feeler arm in up position
You may have a broken icemaker and needs to be replaced.  The internal parts are solid state electronics and they can break.
Jun 18, 2008 | LG LFX25960ST Stainless Steel French Door...
Ice maker quit - LG refrigerator model LFX25960ST, ice maker PN 5989JB0001A
I have the same problem.
Ice in the gears.
Splash from opening and closing the door when liquid water is present seems to be the logical problem.
I had cleared the ice before, thoroughly dried the icemaker and reinstalled it. It worked until I adjusted the icemaker to make large cubes.
I will reinstall it and see how long it last. I will also complain to Sear about the short life of this device.
Dec 27, 2007 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960 Bottom Freezer French Door Refrigerator Logo
1,512 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
