Question about Maytag MDE2400A Electric Dryer
Magtag Dryer MDE2400 Dryer won't turn off
I am having the same problem with my Maytag dryer. I have to manually turn the machine off when the chime sounds, There is a digital diplay that is showing that looks like a marquee that goes around and around. The heat in the dryer goes off when the chime sounds but the drum keeps turning. Can't find what this means in the manual. Anyone know what to do?
  • Anonymous Mar 30, 2014
    Dryer will continue after finish chime goes off and digital display will not read anything
On our Maytag dryer, the looping marquee lights mean that the dryer is in "wrinkle" mode. This means that the wrinkle mode has been selected. In this mode, the dryer continues to rotate on and off after the heat cycle has ended. It does this to keep the clothes from wrinkling -- and it displays the looping lights.
Posted on Aug 26, 2012
    President:
  • 1,714 Answers
There is a timer motor that is usually controlled be the operating thermostat, that is not working. It could be either the motor or the thermostat at fault. It will need to be tested.
Posted on Jul 24, 2009
Magtag dryer drum will not turn is there a belt that needs to be replaced
If you hear the motor run, but the drum doesn't turn, it's most likely a broken belt.
Mar 11, 2014 | Maytag Neptune MDE7500AY Electric Dryer
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
When running smell burning comes out
Replace the high limit thermostat. Here is the thermostat to order.
The thermostat is located to the top of the heater assembly.
Nov 12, 2012 | Maytag MDE2400 Dryer
What happens when the timer goes out my maytag atlantis dryer
how do I replace the timer knob on my Magtag Atlantis Dryer MDG7400AWW
Jan 10, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
How do I remove the front of my MDE 2400 dryer?
two clips one on each side located in the gap between the top and the front slide a knife into each clips maintaining a little positive upwards pressure top should rotateupwards being hinged in back
Aug 07, 2009 | Maytag MDE2400 Dryer
My magtag dryer mde9520 won't heat. How do I tell
You need a multimeter to test the voltage and continuity
Jun 30, 2009 | Maytag Dryers
No heat from dryer
You have a bad heating element and or a bad high limit switch. Check them for continuity with a volt meter. No continuity, replace the part.
May 24, 2009 | Maytag MDE2400 Dryer
Maytag electric dryer won't start
Hi!! remove the top base cover of the dryer not the timer portion..
Jan 04, 2009 | Maytag Performa PAV2200
Maytag MDE2400A Electric Dryer Logo
293 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
