SOURCE: Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me [email protected]
SOURCE: LG RU-42PX11 42 plasma TV has black bar
it seems to be a bad connection somewhere but I disconnected the ribbon cable and got a verticle line of snow instead of a blank line. the line is about 34 mm wide and starts 285 mm from the left edge starts on the Blue and goes to the Red pixels. so if they are 1mm wide that would be 34 bands of color.
I would sure like to figure out the solution to this one or I got a TV I need to throw away cause the o'lady is gonna bust my balls if I can't fix this!
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
SOURCE: I have a horizontal line going across the picture of my tv.
The panel is bad and will need to be replaced.
