Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Paloma tankless, gas, water heater, error code C7 76
Paloma tankless water heater, 2 yrs old, C7 76 error code. How do I fix this?
  • 244 Answers
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
Posted on Nov 01, 2009
  • 3 more comments
  • Michelle Oliver Nov 17, 2009
    Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support .
    If this helps, please indicate so.
    Mike//jzklipper
  • Drew Aldridge May 11, 2011
    Even though the original post by JZKlipper is over 2 years ago, and his comment is from a year ago, I called this morning his information still holds true for May of 2011. My capacitors are clearly raised on the top. This is funnily enough, the 4th item at home that have had blown caps, that I have replaced myself. This control board I have left for Rheem to repair though as it is till in warranty.
  • rpatterson35 Sep 08, 2011
    I just called Paloma and as soon as I said code 76, he said we'll send you a new control board and replacement instructions. It's a controller error that needs to be fixed by replacing the PCB. I looked at the four capacitors (green with silver top) and two of them had a yellowish-white crust on top of them.
  • c723
    c723 Nov 10, 2012
    Yep, I'm looking at them right now. They are blown and leaking. I was not expecting the whole board to be coated in a glue, however! I'll call and see if I can get a replacement free. If not, I may have to hack it from the other side. I'll post a photo.
  • c723
    c723 Nov 10, 2012
    Just called. They're sending a board and a tech.
My Paloma tankless water heater had a code of C7 - 76. I called the service center at 866-720-2076 and they stated this code showed a communication error between the Water Heater and the thermostat; they stated it was still under warrantee and they would replace it for free. Also, I found out there was a recall related to the door properly shutting. To make it work while waiting for the repair, I would turn off the thermostat, wait 2-3 minutes, and turn it back on. Usually it would work for enough time to shower.
Posted on Oct 06, 2010
  • Frank0111 Nov 06, 2010
    I have the same code the only diff is that they are sending a contractor to replace the board instead of just sending me the board.
  • calmike54 Jun 02, 2011
    Thank you for your posting. It was of great help. I called the service center and they are mailing out the board and having a contractor install it.
  • 117 Answers
It's the remote controller remove it(the remote controller wires) and see if it kicks on and works fine, if not you have more problems! it would probably be the printed circuit board
Posted on Jul 29, 2009
My Paloma tankless hotwater heater is not producing hot water. I get error message C 8 76. What does this mean?
Posted on Aug 10, 2009
JZKlipper was correct. Rheem is delivering me the control board.
Posted on Aug 26, 2010
I have error codes ao21 and 76 on a gas heater. the unit will give hot water for 4-5 min and turn off. can any one help
Posted on Jun 25, 2011
On a Paloma 42PVN, 2006 model, we got the C7 76 error. After collecting serial number etc. they arranged shipping of a replacement board and professional installation on their nickle without batting an eye. Good on them!
Posted on Dec 30, 2011
    New Friend:
I am getting error c4 76. Can anyone help?
Posted on Oct 04, 2014
Sandy October 2012
I just talked to Rheem at 800-432-8373. They are sending out a circuit board and "As a courtesy, a technician to install it". They were very helpful. I certainly would recommend trying them first.
Posted on Oct 08, 2012
I second what rpatterson said. Soon as I mentioned that code, he said it was the pcb board and they are over-nighting the new board and will have it installed free of charge! Talk about service! Also, it if I turn the unit off and back on, I typically can get a shower in before it stops working again.
Posted on May 23, 2012
  • Rheem Master
  • 5,353 Answers
Before calling service technician, open following link for Rheem tankless troubleshooting resources including error codes and typical maintenance:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on May 22, 2012
SOURCE:
My Paloma pg-711fr is turning itself off and error 12 comes up
Copy following link for error codes and Rheem-Paloma tankless troubleshoot.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#error
Add a comment and say if this is new installation.
Call Rheem and hear them tell you to call the tankless installer, or hire local service technician to check your tankless computer that heats water, and catch up on required monthly and yearly maintenance. For example cleaning burner and flame rod, or replacing bad flame rod, or installing correct gas line, or checking gas pressure etc.
Fix any tankless problem yourself, any brand tankless, same day for $385, by replacing 1 part: the whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Do not install tankless.
Jul 21, 2013 | Water Heaters
I have a paloma tankles water heater model #ptg-42pvn i am getting an intermitent error code C4,12. what is the problem?
Copy following link for Rheem-Paloma tankless troubleshoot and error codes:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
If unit worked before: Maybe bad PC board. Maybe lack of required yearly maintenance.
Common error codes can be caused by not following maintenance protocol such as cleaning combustion parts, checking gas pressure, checking venting, and air intake, bleeding gas line etc.
Too bad Rheem-Paloma manuals do not show HOW to conduct this maintenance, leaving customer with many unknowns, and no way to oversee that maintenance performed by hired technician is complete, and matches recommended maintenance.
Sell unit on ebay, and install tank-type gas water heater.
Mar 20, 2013 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Error Im getting is C8 82
Before calling service tech, copy following link for Rheem-Paloma troubleshoot resources:
C8 is usually the PC board, or could be failed gas solenoid valve.
82 is gas-type-data-failure = program PCB for proper gas type, or proper altitude above sea level.
If this is new installation, Rheem-paloma might tell you to contact the installer.
If this is older tankless that worked before, then things point to failed PC board. Rheem-paloma may send you new PCB for free if unit still under warranty period for defect parts.
Rheem does not post service manuals, but will send instructions.
Hopefully the success rate for replacing your main PC control board will have better outcome than expected when replacing motherboard on your computer.
Perform regular maintenance to avoid some common error codes.
Aug 16, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My Boch 24ES Highflow Hotwater is showing Code 14 and only runs for i minute then shuts off
Code 14.
What water heater do you have?
Question posted under tankless Bosch, but these error codes start with a letter.
Rheem/Richmond etc Tankless has error code 14
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
Call tankless service technician.
Ask technician how much it costs to have recommended yearly service.
Or install whole new tank-type gas water heater yourself for $350 from local box store, and avoid the entire headache, then sell tankless online for parts.
Aug 09, 2012 | Water Heaters
Error 13 paloma tankless hot water system. no hot water
Before calling service technician, open following links for error codes, Rheem/Paloma chat and tech support, and possible manual:
http://www.fixya.com/support/t3444443-paloma_tank_less_water_heater_flashes
Error codes are considered start-point for troubleshooting.
Tankless manuals recommend yearly service including burner cleaning, gas pressure and plumbing check, de-liming etc to prevent problems and so technician is familiar with that specific unit.
Aug 05, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
Paloma tank less water heater flashes code C4 13 and we have no hot water?how to fix it?
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 16, 2009 | Rheem Paloma Tankless Water Heaters...
I have a paloma tankless water heater about 3 years old model PTG-74PVN and it works for 2 minutes and shuts off with error code C4 and 13 flashing. (City water pressure is fine)Can anyone help? Thanks...
Nov 03, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My new tankless WH stopped working. It gives hot water for about 15 sec, then starts flashing C7 12 or C2 11. How can I fix this, We had it for a month now & it worked before.
11 The Gas Shutoff Valve is not opened
completely.
12 Gas Service has been interrupted.
LP Gas is running low. (LP models only)
I think C7 is where the startup sequence ended...and then you get the error code
If less than a month old...contact your customer support
Nov 01, 2009 | Rheem EcoSense by 7.4 GPM Outdoor...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
19,483 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
Steve Allison
Steve Allison
Sean Lavelle
Sean Lavelle
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
