Question about LG Shine KE970 Cellular Phone
Applications permissions read/write user data
Applications permissions read/write user data are always set to never allowed for applictaions i download
How to download fexplorer in .jar format
thumbsup.gif FileExplorer v3.0 alpha
[img src="http://handheld.softpedia.com/images/software/screens/FileExplorer-Java-0.jpg" border="0" alt="">
FileExplorer is a program for managing files on the phone and memory card.
Current features include hiding/unhiding of folders and files, password protected access to the program and copying and moving files.
It also features a slideshow viewer and image viewer. Will NOT open other files except jpg and png. This is NOT the final version. Its a pre-release build.
IMPORTANT Settings before running FileExplorer:
After FileExplorer has been installed you'll need to configure the Access Permissions to allow FileExplorer to access the phone local file system and the internet. How this is done depends on your phone. Please read the below section for instructions for your phone type.
Configuring Access Permissions for FileExplorer
Sony Ericsson phones:
Go to either Applications or Games (depending on where you installed FileExplorer). Highlight FileExplorer, but instead of opening it, press More->Permissions.
Select Read User Data and set the access permissions to "Ask once" or "Ask Always". Select Write User Data and set the access permissions to "Ask once" or "Ask Always".
Nokia Series 60 phones:
Go to Tools > Manager > FileExplorer > Options > Suite settings
Select Read User Data and set the access permissions to "Session" or "Ask Always".
Select Write User Data and set the access permissions to "Session" or "Ask Always".
Nokia Series 40 phones:
Go to FileExplorer->Options->Application access->Phone access
Torch Keys:
Left Softkey(Nokia): Change color
Right Softkey(Nokia): Go back
UP/DOWN arrow: Increase/decrease brightness
LEFT/RIGHT arrow: Cycle through preset colours
8 key: Toggle Circle light or Full screen light
0 key: Reset all settings
What's new in this release:
· Shows hidden files and folders with separate icons than the normal ones.
· Improved the support for Sony Ericsson phones. Should work but haven't tested though. Do send feedback
· Added support for zip files and nokia themes but it's under work and will not work.
· Changed the UI a bit adding a shortcut to jump directly to a path
· Added a torch with different colors. The flashlight doesn't work yet.
· Added Nokia Theme creator UI. Still under development.
· Support for zipping files and upzipping them. Working on them. To get torch which remains ON permanently press the UP arrow which changes the brightness level.
http://www.symbianize.com/attachment.php?attachmentid=52054&d=1216885320
Symbianize Forum
Apr 24, 2014 | Nokia ASHA 200 Dual Sim Gsm Unlocked...
Tip
BlackBerry Tour: How to change app permissions
Every app that you install on your BlackBerry Tour has a set of permissions that tell it what functions or information it can or can't access. For personal, business, or security reasons, you may at some point want to modify your apps' permissions. Below is the procedure for changing app permissions on a BlackBerry Tour.
From the main screen, press the BlackBerry button (to the left of the trackball) to bring up the Home folder. Scroll down to Options (the wrench icon) and select it. From the Options menu, select Applications.
On the Applications screen, you can view three different categories of apps: Third Party, Add-ons, and Core apps. Select the type of app that you want to modify, and all of the apps of that type will appear in a list.
From the list, scroll down to the app that you're looking for and highlight it, then click the BlackBerry button. Select Edit Permissions, and you'll see a list of all of the permission categories for that app and what they are currently set to. You can modify any of the individual permissions however you want; for example, you could allow USB connections for a specific app while denying Bluetooth connections.
Be aware when modifying app permissions that certain apps will require certain permissions to function. For example, a GPS program probably won't be able to function if you deny it the permission for Location Data. Some core apps -- like BlackBerry Messenger -- won't even allow you to edit their permissions.
Your BlackBerry has a default permissions configuration that it applies to new apps, and you can modify this default permission list as well. To change default permissions, click the BlackBerry button from inside an app's permissions and choose Edit Defaults, or click the BlackBerry button when in the prior Applications screen and select Edit Default Permissions.
on Jan 06, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Nokia s40 nokia 2700
firstly install these applications from Nokia store....third party s/w might not work properly. install application with mmc inserted and use them with mmc inserted............Permissions like always allowed/ask first time are only for network (GPRS) access....Mobyexplorer requires net.........many free applications also require net access as they carry some ads....if these permissions are denied then application closes......but be sure....if u select always allow/ allow first time, data usage charges will be applicable
Mar 13, 2014 | Nokia 2700 Classic
Wd my passport retrieve data
Step 1:
You might not have the appropriate software installed on your computer to show / read the files
IE: adobe flash , directx , win zip , codec , word ...... Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Feb 08, 2013 | Western Digital 1TB My Passport Essential...
Iomega 1tb drive have files hidden
Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available. Hope this helps.
b>
Dec 10, 2012 | Iomega 1TB Prestige External USB 2.0 Hard...
My preferences can not be read
Here's how to fix the problem
1.C:\Documents and Settings\[user]\Local Settings\Application Data\Google\Chrome
2.Right click on "User Data" folder
3.Go to "Security" tab
4.Click on "Advanced" button
5.Chek the last option "Replace permission entries..."
6.OK (this will take a few minutes)
7.OK
Oct 16, 2012 | Google Chrome
I have nokia 6263 t mobile, the applications are set to not allowed and i cant have the application access option in it. what can i do . pls say me the answer.
Here, before you open the application, click first the options, under it is the Application Access, you may see Communications, Data Access or Auto-Start, under Communications you may see Network Access...all you have to do is click Ask Everytime or Ask First Time Only... Do it with the rest, in Data Access (Read user data, Add and Edit Data) and Auto-start.... just set everything Allowed...okay!
Jul 18, 2011 | Computers & Internet
How to stop 'allow network access' pop up window in nokia 7610 supernova. Its very annoying that it always comes in between when i am surfing the net.
you download the java software first before you can run: on the phone to find your JAVA applications. Then select the section to stop the application software, press the left soft key operation, go to see the applications access the. Application access - communication - network access, if the software has a license certificate, then select Always allow, no election for the first time asked.
application software access - communication - data interchange, if the software has a license certificate, then select Always allow, no election for the first time asked.
application software access - data access - read user data, select Always allow the software without authorization certificate for each inquiry to the election.
application software access - data access - increased selection and editing of data is always permitted, the software did not authorize the certificate to select Always ask.
need to read the phone system, network or application software to download the JAD is authorized with the certificate.
this way can avoid the use of mobile phones, java software, always prompt " allow network access " this problem, this method is suitable for the Nokia S40 operating system models.
Aug 14, 2010 | Nokia 7610 Supernova Cell Phone
LG Shine KE970 Cellular Phone Logo
141 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
