Question about Kenmore Washing Machines
How to remove outer washplate from. kenmore
How to remove outer washplate from kenmore calypso washer . I have a small part of ziper underneath the outer washplate.
  • 15,935 Answers
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. NOTE: I would recommend using duct tape to keep the lid closed and gently place the top against a wall for support. Use a towel between the cabinet and wall to prevent any damage to painted surfaces. This also reduces the strain on the top panel supports.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the wash plate center dome from the wash plate. This is the center cone on top of the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the main wash plate should lift out, exposing the inner wash plate. This is another cone shaped device located under the main wash plate. Remove the inner wash plate, using care not to damage the gasket under it. It is common for clothing to become tangled in the leveler or u-joint under this inner wash plate.
6. When all required maintenance is complete, reinstall the inner wash plate, ensuring the gasket is seated under it. The inner wash plate is keyed and should only install one way.
7. Insert the main wash plate and insert mounting bolts. Use a criss-cross pattern when tightening to ensure all bolts are tightened evenly and the gasket seats properly.
8. Reinstall the center dome on the wash plate by snapping it back in place.
9. Reinstall, the balance ring on the wash tub.
The following is a parts list of the most common items that may require replacement when you experience erratic motion of the wash plate, and/or clothing becoming damaged or entangled:
Wash Plate Dome
Main (Outer) Wash Plate
Inner Wash Plate
Leveler Assembly
Inner Wash Plate Seal
U-joint
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
How to remove the washplate (agitator) to remove loose change .I have removed the plastic cap and removed one bolt but it still doesnt lift up, help
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137800&diagram_id=28247413#d28247413 The Impeller or agitator can be removed from the washing machine by pulling the top cap off of the impeller or agitator and removing the 7/16" bolt that is hidden underneath. This will allow you to examine and replace the agitator roller cams or lift the inner wash basket out to access the outer tub, tub sump, and lint filter for cleaning.
Dec 27, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Calypso washer clothes get stuck under the washplate ..the gap looks too wide between tub and washplate...does the washplate need replaced,, or is the plastic seal around the washplate replaceable???
THE PLATE CAN BE REPLACED, GET ONE FROM YOUR LOCAL APPLIANCE PARTS STORE OR SEARCH ON LINE, SEARSPARTSDIRECT.COM, REPAIRCLINIC.COM, ETC. GET MESH BAGS FOR YOUR SMALL ITEMS. THAT WILL PREVENT FUTURE PROBLEMS, IE: PUMP GET STUCK AND BURN(COMMON PROBLEM)
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How do I remove a small part of ziper
You go buy a magnetic or three hook flexible retriever from your hardware store and go fishing down the side.
Or if the zipper is floating about loose you take the back off the machine after dumping the outlet hose into a bucket to drain off the water.
Tip the machine forward or backward so that the outlet hose from the drum to the pump is as near to the ground as possible then remove the clip retaining it to the outer drum and your zipper should be within grabbing distance.
Make sure you have an old towel underneath the hose before you crack the joint
Jul 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Remove a small part off ziper from underneath the main
Did you try a shop vac? I don't under stand what you are asking ? the agitator come off if you pull on it.
Jul 24, 2009 | Washing Machines
How to remove a small pice from uderneath a main washpla
Have you tried a shop vac with a nylon over the end of the suction pipe yet ? Usually works wonders.
Kenmore calypso has clothing stuck
I believe the problem is the Outer Wash Plate. Replacing it may fix your problem. I am about to do that to mine, so I don't know yet. The outer plastic 'seal' or rim of the washplate should be touching the inner surface of the stainless steel wash basket. So it catches clothes. I just installed a u-joint kit today, so needless to say, I got out the washplate and retrieved my clothes on the way to replacing the u-joint. It involves leaning up the upper lid and cover, removing the tub ring and balance ring and the dome. Then there are 6 bolts to remove the outer wash plate to get to your clothes underneath. Might as well replace the washplate while you are at it. to download the manual, copy this https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
into your internet explorer address line and save the manual. page 36 starts the instructions I used to remove the washplate and other items. I spent a LOT of time cleaning the gunk out.
May 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso once wash cycle is selected. The machine will fill then stop and there will be a humming noise
does it wash or spin anywhere on the dial.  If not, the coupling that connects the motor to the transmission is defective and need replacing.  A $20 part
Mar 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso
If you have already removed the outer washplate, the inner wash plate should just lift off the leveler and u-joint. The washplate dome refers to the center cone that fits on top of the outer wash plate. This piece comes off by inserting a screwdriver in the slots along the sides and gently prying to release the locking tabs. The mounting bolts that secure the outer wash plate also secure the inner wash plate to the u-joint assembly. There is a seal under the inner wash plate that may be holding it on. I don't know of anything else that would be holding it in place. Searspartsdirect.com has an excellent exploded view diagram of the wash plate and components that you may refer to provide you with a perspective on how everything fits together. I hope you find some of this information helpful. Please post back and let me know if you are still having problems.
PS You may have to resort to using a rubber mallet to lightly tap on the inner wash plate to knock it free.
Sep 28, 2008 | Kenmore Elite 21086
Kenmore calypso washer
LD is an error code for 'Long Drain'. The water pump may be clogged, there may be a clog under the washplate where the water exits the tub or a clog at the check valve. The best place to start is the water pump.
Jul 12, 2008 | Kenmore 20172 Top Load Washer
Clothes getting sucked under agitator
I was able to find information on another web site with a Whirlpool Calypso repair manual: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Check out steps 5 and 6 on page 36:
6. Using two (2) flat bladed screwdrivers, 90°
apart, in the notches provided, separate the
dome from the outer wash plate. (Fig. 3-11)
7. Remove the six (6) 3/8” bolts securing the
outer wash plate to the universal joint.
(Fig. 3-12) Remove the outer wash plate
from the basket.
That gave me enough room to lift the outer wash plate and remove three napkins and a wash rag.
P.S. Take precautions to keep the bolts from dropping under the outer wash plate.
Dec 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
304 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
