I have a Xerox WorkCentre M20. Getting the error message: "OPEN HEAT ERROR." How do I repair?
  • mdavis781 Jul 24, 2009
    Tried this several times. It did not work. What should I do to get the machine working?
    Genius:
  • 1,043 Answers
The error can sometimes be cleared by resetting the machine by pulling the plug, waiting a few minutes, and then plugging it back in and powering up. If that doesn't clear the error then that indicates that the fuser rollers are not getting to their correct operating temperature. They should be checked by a Xerox technician and replaced if necessary.
Posted on Jul 24, 2009
  • 5,081 Answers
All of the heat errors point to the fuser assembly. To clear the code, try unplugging the machine for 3 minutes and then plugging it back in. The “Open Heat Error” means that the machine was under temperature.
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
How do you fax papers to someone?
Download the user guide from here: http://www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
Open the table to contents and look for facsimile instructions, and then just follow them.
Mar 11, 2015 | Xerox WorkCentre M20i All-In-One Laser...
-Xerox workcentre m20i. -Yesterday turned machine
hi enviro,
so its the supply inside the Xerox is the next to be checked or fuse too..a technician nearest you can help open it.
mastergani
Jan 21, 2011 | Xerox WorkCentre M20 Black and White...
I HAVE A M20 XEROX PRINTER AND I AM GETTING A MESSAGE THAT SAYS OPEN HEATER ERROR WHAT DOES THIS MEAN
The heater rod (quartz lamp) inside the fuser roll is cut/ burned. Unfortunately Xerox will not support it as spare. You should buy a new
fuser.
Replacing it is easy. Just a few screws to take off on the right side plus two electrical plugs.
Oct 03, 2010 | Xerox WorkCentre M20 Black and White...
Need to replace the fuser unit kit in a xerox m20 copy machine
First unplug the machine.
Open the right side door. there are four screws to remove. Unplug the two plugs to it.
Pull out the fuser modual.
Insert the new fuser modual, and release or flip the green jam tabs.
When put on the four screews make sure not to over tighten, just a gentle snug is needed.
Close the door, pug machine, and turn it on.
If the fuser fan is not working, this can cause the fuser to over heat again. Make sure the fan is truning by viewing it from the back.
Good luck.
Jul 14, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Error message Xerox Phaser 8400 07.010.43.4819
The post was a little confusing. You have an 8400, correct? (not an M20)
The 07,010 error is normally a bad process motor 401-1000-80
You should also change 2 camshafts at the same time 401-1003-80 and 384-1874-80. The whole job is medium difficult and takes 2-3 hours.
Whit
Item, Inc.
May 09, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
There is a problem in the
fuser unit.
Unplug the power cord and plug it back in. If the
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
FAX ERROR MESSAGE
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
Jun 19, 2008 | Xerox WorkCentre M20i All-In-One Laser...
90 people viewed this question
jasbo
jasbo
