Question about Garden
Stihl FS 45 throttle problem
I have borrowed a Stihl FS 45 from a friend. It was difficult to start so I set all the carb dials in accordance with the manual. When adjusting the head starts spinning so I then turned it back a couple of turns as per the manual. It starts fine but when I press the throttle nothing happens. Is there any way that the throttle can be adjusted or is this broken. Literally nothing happens in terms of revs when I press the throttle up and down. As the head rotates when I adjust the carb I am guessing there is nothing wrong with the shaft.
  • rdgrieve Jul 24, 2009
    Thanks for the quick response!
    No it does feel like it is not connected to anything. Is the cable a self-fix or back to a maintenance shop?
  • Kerry Degrand May 11, 2010
    can you see the throttle lever on the carb moving when you work the throttle lever if not its the cable.
  • 112 Answers
Its a self fix just get a new one it will come complete
Posted on Jul 24, 2009
FS 45 no power problem. Unscrew the exhaust tube and pull it it. Clean the screen with a stiff wire brush.
Posted on Apr 29, 2012
ADJUSTING HIGH AND LOW ON A CARB FOR A STIHL FS 45 WEED EATER
Hi..in general i always set the high and low screws at 2 turns out from a complete stop..and please dont tighten the screws too tight..it will bend the needles...I think it will..or should run at them settings...as far as the gas out of the engine..it is or has a problem with the carb...did you remove the carb...? Also try starting it with only starting fluid for a very short time..this is how I check to see if all else is ok..spray it in the carb in take...
May 05, 2016 | Stihl Garden
I have a Stihl Weed eater will a FS 45 carburetor fit on an FS 90
NO. The FS90 is a 4mix engine and the carb has a (sump) on it which has a pulse pipe going to the bottom of the crank. The FS45 is a totally different carb configuration, and doesn't have the sump. FS90 carb is an C1Q-131A
The FS45 has several carbs that fit:-
C1Q-S97
C1Q-S71
C1Q-S66
C1Q-S58
C1Q-S44A
C1Q-S53A
Apr 13, 2016 | Stihl Garden
Need a new wire from throttle trigger to carb
throttle cable, call a Stihl dealer. Part look-ups for Stihl and others are not available online
Aug 28, 2013 | whipper snipper stihl fs 38
Stihl FS85 starts fine, But not take full throttle
Pumping the primer bubble while the engine is running should cause the engine to over fuel and stall (if the tuning is correct). Sounds like its not fueling enough, pumping the primer is forcing fuel through the carb causing the engine to pick up rev's, but this is soon exhausted which is why it wont rev on the throttle.
* Check that the fuel line is not damaged and drawing in air. (if this is intact try the next step)
* Strip and clean the carb. Replace any diaphrams if needed.
* Check gaskets seal between carb, air filter and cylinder.
Just out of curiosity what standard carb settings did you use.?
May 23, 2013 | Stihl FS 85 Weed Eater
Where do I find a free repair manual for Stihl FS 46
If you have a nice Stihl dealer he (or she) might be nice enought to print you the specific repair information that you may need but no place that I know of offers the complete manual for free.
Sep 06, 2010 | Oregon Scientific Complete Carburetor for...
Stihl FS81(older style) brushcutter.New Carby dies under throttle
The problems you are having sounds very much like a blocked exhaust port/silencer. On these small two stroke machines it is normally the cause of lack of power or not revving. Happy gardening !!
Stantheman 19/09/2010
Mar 13, 2010 | Oregon Scientific Complete Carburetor for...
Stihl carb
Try this link. It has the carby settings on page 26 & 27 of the Stihl FS 45 manual.
http://www.mccoyslawn.com/parts-manuals/Stihl/FS45_46_Manual.pdf
Apr 17, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
1,885 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
