Question about Jenn-Air JES9800A Electric Kitchen Range
I have a jenn air oven and stove top. the
I have a jenn air oven and stove top. the electric went out on our island and when the power was restored the oven said ''power loss'' and also is showing A TIME on the clock. None of the buttons will push and the oven doesnt' work. the light comes on when I open the oven door, but none of the buttons push on the face of the oven. The stovetop is fine. What do I do??? thanks
  • 41 Answers
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Posted on Jul 24, 2009
If you have a brief power outage to your residence and the control Panel Window on your Jenn-Air slide in 30" says "Power Loss," hold in the Cancel button. The "Power Loss" message that is on the control panel should go off. I am not sure why this is not covered in the manual under Troubleshooting. Hope this helps!
Posted on Nov 03, 2013
Thanks yecalam13-
Having a similar problem & found this thread...
The power went out on my older Jenn-Air W131 wall oven. The breaker was not tripped but turning the breaker off & back on again restored the power!
Posted on Aug 06, 2009
Electric stove works, oven turns on briefly then shuts down
Try turning off the power at the switch again and leave it off for a little while, sometimes the microprocessors become confused and need time to re adjust.
Apr 10, 2014 | Jenn-Air Kitchen Ranges
The display and buttons are dead, no display or oven lights but electric starter still works on stove top
find the breaker for the stove and turn it off for 2 minutes then back on, if that does not work look on back of stove in area of controles for a small reset button, some time they are hidden just inside a small hole
Jan 09, 2014 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn aire oven no power.
go to jenn air web site -find your stove model number and find user & care guide that should help you
Mar 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven not working
This is a tough one...but I'd try to see if you have good electrical connections.  Turn off the power at the breaker box...two breakers.  Next, check ALL connections from the box to the terminals inside the stove.  They should be bright, clean and tight.  If this isn't it...the timer unit may be bad.
Nov 23, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
Jenn-Air JES9900BAB Electric downdraft range with convection oven
sounds like the power outtage fried the clock. unfortunately, none of today's ovens come with a UPS (uninterruptible power supply), sort of like a power box for your computer. if he power goes out, it'll fry the electronics, including the clock.
have a technician come out and test the clock to see if there is power going to it and what voltage is coming out of it. i would suggest replacing the clock.
Apr 05, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air JES9800A Electric Kitchen Range Logo
1,431 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
