Question about Microwave Ovens
I was changing the lightbulb underneath the unit when the bulb broke causing the microvave to shut down
  • 441 Answers
This is a design issue, if you did not unplugg the micro when replacing the bulb you blew the control board in the micro wave. It can be replaced but is not cheap, you might want to consider replacment. If you send me the model # I can tell you just what the parts would cost.
Posted on Jul 24, 2009
How do I replace the lightbulb in the microwave and what light bulb do I need to purchase?
to replace the bulb in microwave ovens you will have to take the outside case off the unit as the bulb placement is not accessible from inside the oven
when you get to the bulb take it to an appliance repair shop and they will have a bulb
Sep 09, 2015 | In Microwave Ovens
Lg lmh2016st microwave shorted out after changing lightbulb now doesn't work
We see and repair this a lot. The problem is on the controller assembly.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Dec 01, 2013 | LG LMH2016ST
Short Circuit in changing light bulb in KHMS147SS has caused the unit to power completely down. Is there a fuse?
see this causes and fix it. God bless you
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 23, 2012 | Microwave Ovens
How do I change the lightbulb in the unit?
remove the screws holding the outer shell and carefully remove it.... the bulb should be accessable then. make sure the replacement bulb is equivelent to what is in the microwave now. do not operate the microwave without the cover on it. if possible test the bulb before you put it in.
Jan 17, 2010 | Sanyo EM-P410W Microwave Oven
Spacemaker xl1800 - heats, but lights and carousel out
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can't get the light bulb out from under the counter microwave
the clear rubber is from the factory to keep the bulb from turning you need to cut this before you can replace the bulb . thats why the first bulb broke . there is no trick to getting them out , see if there is a glue strip on the broken bulb that if you chip off it will then turn . just be carefull what ever you do . ge thinks there microwave will die before the lights burn out ! it screams of there trust in there products . good luck
Jan 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Sep 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How do i change the lightbulb in my Zanussi ZCM32T Combination Oven
hi
two VERY important things... first, turn off the breaker (power) to the unit, and second, do NOT touch the bulb with your bare hands (use thin gloves or rubber gloves), you don't want to get any thing on the bulb, like grease. I don't know this exact model but, to remove the bulb, there should be a grill on top of the microwave, take that off and there should be a panel above the bulb inside, remove that and you should be able to reach the bulb now.
Mar 21, 2008 | Microwave Ovens
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
87 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
