Question about GE Profile JKP56 Electric Double Oven
Is it easy to replace the keypanel of the GE
I have a GE profile JKP56BOD1BB oven.THe keypanel is giving error F7 and F1 constantly. I called a tech he said the key panel is defective and had to replace. The total labor and replacement cost total approx 450$. I am trying to see whether if I buy the part then can it be easy to fix it or not by myself.
Thanks
Tapas
    President:
  • 744 Answers
Hello, The simple answer is yes it's not too hard...Normally you have a couple of screw located underneath the control panel. In most mordern ovens today they just consist of 2 components, the EOC (Electronic oven control) and the touch pad which basically cosists of everything you see(the whole panel). If you are replacing the touchpad..remove screws holding old panel in...pull wire harness from control board (dont worry where they go because the will only fit in one place) remove tape from EOC and relocate the control board to the new touchpad panel...reattach wire harness and tape in the new touchpad panel and hook back on oven ..screws in and your good to go. if replacing the control board (EOC) drop touch pad panel from oven and pull wires install new control then reassemble..easy!. One thing i would check though before purchasing the part, check to see it is the touchpad and not the control board...Here is how to do it...shut breaker off...pull out control panel...remove ribbon for key pad from EOC the re install panel..go switch breaker back on. leave for 24 hours..if within the 24 hours the error messages come back it's the EOC that is bad, if the error messages do not come back then you can be sure it's the touchpad. I would check this before buying the part since they are expencive and offten non returnable. Good Luck!! If you have any other questions or concerns please feel free to comment again. Thanks for using Fixya!! Mike
Posted on Jul 24, 2009
  • 2 more comments
  • Glen giaquinto Aug 17, 2012
    I am having the same problem and did what you advised above. I do no get the f7 message anymore but instead now get F0 with the ribbon connected. Does this mean the key panel needs replacement?
  • RENEE GOUGH
    RENEE GOUGH Oct 13, 2013
    Help! I have fixed my control panel many times, but this time I just cannot get the panel to fit flush to the wall. Any tips?
  • RENEE GOUGH
    By the way, if like me, you continuously get the F7 code error on your control board, this quick fix works great! I had followed another user's advice to put a bit of card inside the ribbon to absorb humidity (cause of error code). Did that a few times and it worked great but kept breaking again. My son's teenage friend said to me over a bowl of spaghetti "hey, why don't ya just put a paper towel in there?" VOILA! It has worked SO well! (folded and fitted neatly inside that ribbon). From the mouths of babes!
  • RENEE GOUGH
    These f7 code issues are from the GE double oven. Much cheaper than buying a new control panel at $350! Or a new oven at $2,500! Or calling someone out. Paper towels. Genius!
GE profile oven 326B1230P001 error code F7 will not go off. what does it indicate?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Sep 05, 2011 | GE Profile JTP18 Electric Single Oven
I turn the oven to 350 and in five second's it beep's and we get a f3 and sometimes f7 this is very frustrating! I take the over off and play with the wires and put it back together and sometimes it will...
I will give you the meaning of the error codes and possible solutions.
F3 Open Sensor circuit, Open (blown) sensor fuse or bad sensor.
More than likely, you have a oven sensor that needs to be replaced.
F7 Problem with the keypanel, possibly, a function pad button is stuck.
Attempt to clean and unstick button. If this fails, you may have to replace the
keypanel.
I hope this helps you
Feb 02, 2011 | GE JKP15 Electric Single Oven
Ge profile convection oven giving error code F7. What parts do I need
Hi
Thanks for using FixYa. Error F7 means that the function pad button is stuck or the clock has gone bad. If you are unable to unstick the button then to resolve this issue you’ll have to replace the electronic range control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | GE Profile JTP18 Electric Single Oven
Cannot turn off the alarm - show F1. I turned the power off for 2 days - no help. When you hit clear off - it stops for 10 or 20 seconds then back on.
F1 code
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced
Good luck and please rate 4 thumbs for the free answer
Mar 11, 2010 | GE JTP45 Electric Double Oven
Oven flashing F7 serial number is jgrp17bew288
F7 code
Mar 10, 2010 | GE Profile JT910SASS Electric Single Oven
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
JKP18 WALL OVEN IS A PIECE OF JUNK
http://www.fixya.com/howto/h155060-dreaded_f7_error    Go to the above link.  I will fix it.
Aug 17, 2008 | GE Profile JTP18 Electric Single Oven
F1 Error Code
According to the GE website, F1 usually means a problem with the keypad. You might try my solution for the F7 problem which is similar in nature. Go to the following link:
I have shared my solution with more than 1900 folks and most report success.
Please let me know if it works for you at:
hutchipop@yahoo.com
Good Luck,
Powerman
Jul 16, 2008 | Ovens
GE Profile Performance Double Oven
I was getting only the F0 error code. The wiring diagram inside the stove said F0 indicated a bad off button on the keypanel. There were instructions to check the ribbon cable on certain lines, with values for the resistance. It seemed to check out, so I ordered a replacement and voila, it worked.
Jun 11, 2008 | GE Profile JTP56 Electric Double Oven
F1 Error Code
try fix at http://www.fixya.com/howto/h155060-dreaded_f7_error
this is a common error and easily fixed
Dec 19, 2007 | GE Profile JTP18 Electric Single Oven
Open Questions:
The convection fan comes on intermittently, starts smoking then goes off. Temperature on the display doesn't move from 100F (then it did). My wife left the door closed while it was on broil last night (not sure how long), and this morning I woke up to the smell of burnt electrical and something (one of the fans...? not sure as it was far earlier than I usually get up) running that stopped when I opened the oven door and restarted when I closed it (I'm thinking it was probably running all night). While at work, I turned the breaker off, then pulled the oven out this evening. After taking some of the metal plates off, I put the power back on and turned the oven on for a 450F bake. I don't know if the little cooling fan at the top of the unit is supposed to go on when I have the top exposed and getting plenty of air; it wasn't and it also had a faint burnt electrical smell. After disconnecting then plugging the fan power connector to the circuit board the fan ran for 10-15 seconds before it started smoking and quit. I checked voltage across the fan leads and there wasn't any. I shut the oven off, tripped the breaker, and let it cool. I then tried testing the fan motor directly i.e. bypassing the oven and using a regular outlet since the motor is rated for 120V. It ran for ~1 minute, then smoked and quit. The smoke is definitely coming from the fan rather than any adjoining wires. Is this a case of the fan AND the control board going south or one contributing to the other's demise? I should add that the clock display has been dimming for a couple of years. UPDATE (2/20): I tried just baking (as opposed to convection baking) and the bottom element did come on (I'd reported earlier that it hadn't... that was because I was using convection baking and that does only heat around the fan... just my ignorance on that one). However, the temperature readout on the display did not move from 100F though it was clearly hotter than that in the oven. I then stopped the baking mode and started convection baking. This time the temperature gauge immediately went to 141F and kept climbing. Resistance at the (room temp) temperature sensor (and at the end of the wiring harness plugged into the control board was ~1100 ohms at room temp (as its supposed to be).
Feb 19, 2016 | GE Profile JKP56 Electric Double Oven
See all GE Profile JKP56 Electric Double Oven Questions
GE Profile JKP56 Electric Double Oven Logo
3,073 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
