Question about Samsung Sway SCH-U650 Cell Phone
Sometimes when i turn it on there are lines in the screen
Sometimes really after charging the phone, there will be lines on the screen so that you can't tell what your looking at other then colors. Sometims i'm able to shut it off and on a few times and it will work or take the battery out and put it back in. But it will work wonderfully the whole day and then i go to charge it, and in the morning the lines are there. and i'm rather sure i did nothing to the phone to make it do this. its only like 2 weeks old!
This rumor 2 won't turn on or charge at all. i really need help. thanks
Have you tried taking out the battery and putting it in again? Another thing, sometimes when the battery is completely drained you need to turn on with the charger on (since you can't charge when your phone is off and with no power).
Nov 25, 2011 | LG RUMOR Cellular Phone
Screen picture gets scrambled
i've had the same problem, but it doesn't even work if i leave the battery out for even a full day sometimes. i have to press the camera button over and over again for about an hour or two, waste of time! i tried calling verizon but they told me it was end-user abuse, so i have to pay fifty dollars to replace it!
May 10, 2009 | Samsung Sway SCH-U650 Cell Phone
Screen goes black and phone freezes.
Jessikah - take the phone and have the Flexcable replaced.
Captmartin53 - You need to reflash the phone's firmware for you.
Aug 19, 2008 | Motorola Mobility RAZR V3
Blank or White screen on new Motorola Krzr k1 cell phone
found the solution to the white screen! it's the flip sensor.. what you have to do is open the phone hard and fast... make it so when you flip it open, the sensor knows when to turn the screen on and off.. this may take up to 5 or more times.. jus keep opening it hard and it will eventually work!!!
Dec 05, 2007 | Nokia 6233 Cellular Phone
Red, Red, Red
Remove front speaker grill and access panel......
Turn red screen control down a little...
Cause may be bad CRT.......................................T.
Nov 07, 2007 | Sony KP-51WS510 51" Rear Projection...
S710a problems
I am having the same problem - it won't hold a charge. Red light shows it is charging, but nothing. It may be the battery. I just called S.E. and they said it may be the battery. I ended up getting a new phone since batteries cost almost as much as a new phone.
Jul 03, 2007 | Sony Ericsson S710a
External Display Help
Hi There, If u r external display has a line through this could be the result of a few things... 1. your phone fell 2. you may have got a faulty phone if it is new or even used. to solve this problem u need to have the external screen replaced by a qualified phone repair personel.Hope this helps. Sam !
Jun 30, 2007 | Motorola Mobility RAZR V3
Samsung Sway SCH-U650 Cell Phone Logo
159 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
