Question about Hotpoint Dryers
Do you take of back or front panel of tc71 dryer for belt
Do you take of back or front panel of hotpoint TC71 to replace drive belt
  • norman_hughe Jul 24, 2009
    Thanks for help but it was my selfthe wrong type of dryer . Managed to replace belt
    President:
  • 1,723 Answers
Watch this video, it helps!
Posted on Jul 24, 2009
Hotpoint aquarius condenser dryer tc71 does not heat up
These washer dryers have a lot of problems. you are better off getting a seperate dryer.
Mar 07, 2010 | Dryers
Hotpoint tc71 trips ele every time I turn it on
I would suspect that the heater or thermostat./s are the cause of the prob.
Remove rear cover, and disconnect the heater and stats, and try again.
If it still trips, then you probably have got something more serious to contend with.
Please rate my solution.
thanks.
Nov 08, 2009 | Hotpoint TDC32 Electric Dryer
My hotpoint tc71 drier blows the plug fuse when switched on what is the problem please
boy the list could be very long but this dyer draws a large amount of current (amps) it should be on its own circuit nothing else on the line at least when the dryer is running you said "fuse" if it is blowing a fuse as opposed to a breaker you could try a Time Delay fuse 15 amps might help please do not put a larger fuse in (even though it fits) the wire size dictates the size of the fuse and increasing fuse size with out changing the wire size to accomodate will create a fire hazzard good luck
Oct 23, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint ultima condenser dryer TC71 is running cold
Thermostats rarely go. You could have a bad heater or even a voltage problem. Even if the dryer runs, the voltage can still be wrong, it only needs 110 volts to start the motor but must have 220 to have heat.
Apr 06, 2009 | Dryers
Drum wont move
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint TC71 condense dryer and the stats are gone (as there is very little heat coming from the dryer) Which stat do I replace? The one on the right or the one on the left?
The stats come as a pair, so replace both of them ,even though only one has gone.
Make sure that all your filters are clean, and that all air vents are clean and clear..
This is a common cause of stat failure.
Plz rate this solution.
Thanks.
Dec 16, 2008 | Dryers
Replace a hotpoint tc71 dryer drive belt?
Its not so easy...
if you want i can explain in email
stevenmartin99@gmail.com
Jun 17, 2008 | Hotpoint Washing Machines
Ultima Condensor Dryer
on the back of your dryer you have a heater behind the protruding panel... Either you heater element has gone, but most like the thermal cut outs have blown...these are located in the same area..they are small and round looking and are connected to them are wires either side. Anyways check the conitunity of the termal cut outs using a tester if no continuity then they are no good... hope it helps...
Nov 18, 2007 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
242 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
