Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
WD doesn't turn on
I have the same problema. Did you solve it?
  • fixya632 Jul 24, 2009
    No lights ...
    Master:
  • 404 Answers
Any lights?
Posted on Jul 24, 2009
  • lotfi bouakaz
    lotfi bouakaz Jul 24, 2009
    dead power supply then
  • lotfi bouakaz
    lotfi bouakaz Jul 28, 2009
    then it looks like there is no power going to it, therefore i suggest you try a diffrent power supply with the same voltage and it may bring it back to life.
Mi problema es con mi mi televisor mitsubishi vs-50501 enciende y cuando va a entrar la imagen se apaga a veces si entra y se ve medio rara como que tiene dos imagenes un poco separada o se ve la imagen...
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Dec 19, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Contiually sparking on all burners
Ignitor trigger button/knob pushdown may be jammed, remove power and remove the knobs, spray with a small amount of WD-40 or penetrating lubricant, try to actuate the trigger by pressing it down and releasing, replace knobs if you need to, apply power and see if your issue is solved, if this doesn't solve it, you may need to have it looked at by an appliance electrician.
Oct 21, 2012 | Kitchen Ranges
I am not able to connect my passport to my pc..lead light is steady n it showing in my pc like device is malfuctioned....wht to do ,,plz help asap
Try each of these methods step by step if solved in any step get backup ASAP
the good news is: if the LED is ON you may have a chance
1.Use Minimal cord, detach all other USB's, check your power2.Turn off power options3.Try Restarting your system4.Carefully Try system restore3.Download & update Firmware software from WD website4.You may need to Install SmartWare_Windows_Upgrader first5.In any step if the hard drive was recognized back up your data immediately6.if none of above You will need experts having PC3000 to get your data back
the bad news is that: if the LED is OFF or PC3000 doesn't recognize your hard drive you may need a new exactly the same hard drive with the same SN to replace it's board to get your data back.
unlike other brands which use laptop hard drives, that can be plugged into a PC directly, WD uses it's own board with access services on the hard and if the board is damaged you may have a serious problem.
this is a problem I have been through.
unfortunately the "lovely WD my passport" is Totally Not Reliable and you can not count on it.
May 01, 2012 | Western Digital My Passport Essential...
P0755 wrangler 3 months now and i cant solve the problem
ESTOU COM O MESMO PROBLEMA. VOCE RESOLVEU O SEU?
TEM ALGUMA DICA?
CCEFFAZ@IBEST.COM.BR
Apr 15, 2012 | 2009 Jeep Wrangler 3.8
I have a LG WM2701HV it is less than a year old and sometimes the washer turns on and other times it doesn't turn. I have checked the wall outlet and other electronics work in it and the breaker is...
How much soap are yall using? The washer is supposed to wash with less water. Too much soap causes problemas. Less than a year? Look for items in the filter.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2011 | LG WM2701HV Washer
My WD-60735 doesn't recognize my xbox 360 in HDMI or AV. DVD player works fine in AV, Xbox works fine in HDMI and AV on another tv. Just goes to blue screen on this tv.
have you set your settings for 720p on your xbox then turn the tv on to the right input then turn the xbox on? i had that issue with a previous tv? does the lights on your xbox just spin around?
May 14, 2011 | Mitsubishi WD-60735 Projection Television
Tengo imagen negativa kp/51hw40
Hola!
Pruebe los siguientes pasos para resolver el problema: Asegúrese de que las conexiones de los dispositivos son firmes y seguros. Trate de encender y apagar la opción de Digital Reality Creation en el televisor. Trate de ajustar la nitidez de imagen y ajustes del modo de la TV. Presione el botón FLASH FOCUS en el panel frontal del televisor. Esto modifica la convergencia. Si el problema persiste, pruebe a quitar el televisor de la pared a dejar y conectarlo a una toma de corriente directa sin ningún tipo de protector después de 1 minuto. Pruebe a pulsar el botón RESET en el tiempo remoto en el menú de vídeo y compruebe si funciona. Si el problema persiste, el servicio puede ser requerido.
Gracias por usar FixYa.
Dec 02, 2010 | Sony Televison & Video
Tengo na Impresora Ricoh Aficio 250 y me aparece en pantalla (PROBLEMA SC543) y no me Copias Sacar vu. les agradeceria me ayuudaran Con Este Problema
SC543 is caused by a defective Fusing thermistor. check or replace both center and end thermistor this will solve your problem
Nov 25, 2010 | Ricoh Aficio 250 Copier
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
241 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
