Ovens Logo
Jus Aying Posted on Apr 07, 2017
I have a Simpson Harmony Nova Thermaflow Oven and can't find the operating manual and the model number as worn off. I just need to put in a new globe? Any hints? Thank you. Brenda
2 Related Answers
Anonymous
  • 327 Answers
  • Posted on May 26, 2010
SOURCE: Simpson Harmony Nova Thermaflow Oven (63B906W) won't heat up
Hello,Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Mark Omas
  • 13 Answers
  • Posted on Oct 05, 2012
SOURCE: Grill of Simpson harmony nova thermaflow oven does not completely turn off. A fan like noise happens in the off position and won't stop.
thermostat need replacing
Wall oven Simpson 2001 thermaflow measurements
Contact Simpson directly to inquire.
Aug 24, 2021 • Ovens
What is the power requirement for installing a Simpson 2001 66-647 thermaflow freestanding oven?
For Electric Range - 220 - 240 volt, 60 hertz, properly grounded circuit with 40 amp breaker or fuse protection with #8 gauge wire. With a 50 amp breaker, # 6 gauge wire is required.
The owner's manual below mentions the wattage. (download the document, hit CTRL-F on your keyboard, type in wattage.) You might contact the manufacturer or for that matter the electric company servicing you.
https://john.daltons.info/appliances/Simpson_2001_models_68-642_and_68-646.pdf
Jun 11, 2017 • Ovens
2answers
I'm trying to identify the model number of the
Possible source of assistance, depending on what the exact model number, in case it is not 7580402.
https://spares.bigwarehouse.com.au/index.php?cPath=64677_65668
Sep 15, 2013 • Ovens
2helpful
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Jul 31, 2011 • Ovens
May 26, 2010 • Ovens
2helpful
Griller on simpson harmony nova oven
In my experience, it is normal to leave the the door open when grilling, otherwise it is liable to cause the bakelite handle of the grilling pan to get very hot, and possibly melt or catch fire, and make it to hot to hold the handle.
Plz rate my solution.
Thanks.
Jan 12, 2009 • Ovens
6helpful
Remove light globe from simpson harmony nova oven
The glass cover is a screw in. You will need to remove this by turning anti-clockwise to get to the globe.
Jun 01, 2008 • Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
