Back to:
Tags:
Vacuums
Generic problem for all Vacuums
Kirby G6
posted by Jabaas on Nov 21, 2007
I have no idea how to assemble and use the G6 vacuum Uphoilstery tool?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 22, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1307 votes
Take the front noozle off, but turn the knob in the center of it all the way until it stops, this way when you want to put it back on, and you turn the knob the other way, the belt will be in place. Hook up the hose in its place, then you can use your tools.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Kirby G6:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Filter Queen Cheetah II Ash - MU305 Bagless...
i lost the plug from the main body to the hose and now the...
Vacuums
Vacuum cleaner - plastic fitting at end of hose (machine...
Hoover Floormate H3000 Upright Wet/Dry...
My Floormate tends to dispense, and dispense and dispense...
Hoover U5194-900 Mach5 Multi-Chamber...
My vacuum will run fine for a little bit, but then won't...
Dyson DC07 Bagless Upright Cyclonic Vacuum
I have to hold it at a weird almost fully upright position...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
