Question about Exercise & Fitness
Won't turn on at all.
A friend gave me this treadmill. We moved it to my house, plugged it in, put the clip on my shirt, and I was ready to walk. Nothing! The monitor doesn't light up or anything. No booklet for troubleshooting. It worked good at her house. HELP!!!!!
Treadmill Proform XP 550
    New Friend:
  • 64 Answers
If you have no lights, check the main harness that cary power to the console. Check connection at both ends.
PS Always check outlet to make ssure you have 120 volts.
Posted on Jul 27, 2009
Console working but treadmill not moving
Same thing happens to my treadmill a few times a year, and this is how I got mine working again. I went outside to my main electricity breaker box and reset all the switches. Turn them off then on again. And then did the same thing to my small breaker that's on the wall in my house. Walla...It's working back to normal again!
Oct 07, 2015 | Nordic Track T9.1 Treadmill Walking Deck...
I have the 1750 NordickTrack Treadmill and the screen is "froze" on the SD or WiFi screen. I tried pushing the stop button, shutting off the power, and even unplugging the power cord and it still shows...
try this steps and fix it. God bless you
Step 1
Plug the power cord into a UL 1449 single-outlet surge suppressor and then plug the surge suppressor into an electrical outlet that is not GFCI-equipped if the power does not turn on. If the treadmill is plugged in and the power still does not work, make sure the key is in the console and that the Reset/Off circuit breaker has not been tripped. Press the switch to "Reset" if it has been tripped.
Sponsored Links
Gym Equipment Choose from 1M+ Verified Suppliers. Contact Directly & Get Live Quotes! www.alibaba.com/Gym-Equipment
Step 2
Check the Reset/Off circuit breaker if the power switches off while in use. Wait five minutes and switch the button to reset. Check that the power cord is still plugged in securely; pull the plug out and plug it back in after five minutes. Pull out the console key and reinsert to see if the machine will turn back on.
Step 3
Place the chest pulse sensor tightly right underneath your pectoral muscles or breasts for it to operate properly. Position it lower or higher on your chest if it does not work properly. Wet the electrodes with a saline solution. Walk near the walking belt's center within an arm's reach of the console.
Step 4
Remove the console key and unplug the treadmill to loosen the walking belt if it slows when in use. Turn the rear roller bolts counterclockwise with the hex key 1/4 of a turn until you can lift the walking belt's edges 3 to 4 inches from the platform.
Step 5
Remove the key and unplug the treadmill to adjust the walking belt if it is off-center or slips when in use. Loosen the rear roller bolts with the hex key and reposition the walking belt. Tighten the roller bolts. Walk on the treadmill to determine if the walking belt is centered. If not, loosen the roller bolts again and make adjustments until the walking belt is centered.
Step 6
Recalibrate the incline system if the treadmill's incline does not adjust correctly. Press the "Incline" button and remove the console key. Wait a few seconds and replace the console key. The incline will automatically recalibrate by moving to the maximum incline level and then the minimum level.
Step 7
Press the "Stop" button for a few seconds to turn off the demo mode if the console display stays lit after you remove the console key.
Read more: http://www.livestrong.com/article/241157-nordic-track-treadmill-troubleshooting/#ixzz2geWlKdPR
Oct 02, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
My treadmill won't run, but turns on
It sounds to me like during its move the drive belt came off off the motor that connects the motor to the walking surface. If the motor is not running at all after checking that I would look for a reset on the motor itself and check all connections. Not likely that the motor is fried but that would be the last in line for checking.
Aug 31, 2012 | Proform Exercise & Fitness
Belt is off center
Tighten the rear adjusting bolts until the walk belt it tight enough to lift about 1.5 inches at the sides of the walk belt. After you do this, Turn the treadmill on to speed setting 2, and be ready to tighten the side that the belt is closest to.( if the belt is against one side, start with that side) Tighten only 1/2 a turn at a time and watch the belt start to move. It wont take much once it starts to move. Only tighten each side ( if necessary) dont loosen the bolts. Once the belt is in the middle, leave it alone. The belt is now adjusted. You may see it travel to one side, breifly, but it will return on its own.
Hope this helps
Nov 10, 2010 | Nordic Track NordicTrack Treadmill, A2550
Belt slipping and moving
Here is a basic procedure that will work for the majority of treadmills out in the market:
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centred. b. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill
Jul 15, 2010 | Treadmill Doctor Weslo Cadence Dx10...
Life fitness 95ti belt moving to one side any way of correcting
If the walking belt has shifted to the left, use the Allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left rear roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centred.
Jun 09, 2010 | Life Fitness 95Ti Treadmill 95 Ti
Belt is not the correct speed when you put ypur weight on it...slows down.have to put on 5 to get a 3 walk?
If the walking belt is overtightened, treadmill performance may decrease and the walking belt may become damaged. Remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts counterclockwise, 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each edge of the walking belt 3 to 4 in. (8 to 10 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened. . If the walking belt still slows then lubricate running deck the lube may be purchased from iconfitness.com
May 04, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you2_bing.gif Repeat until the walking belt is centered.
Feb 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
349 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
