SOURCE: front panel locked and remote don't work
Are you sure there is not a problem with the TV set? The set will need to be on to unlock the front panel. Bypassing the V-Chip Lock on most Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it. To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV. To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Good Luck
SOURCE: intermittant remote
yes they do go bad. try cleaning the inside of the remote and check for a bad solder connection with-in the remote. the key pad can get dirty from your handling maybe a good cleaning but do not scrub it just lightly touch the pad with cue tip and alcohol
SOURCE: NAD 7100 How to turn off low level without a remote
You can ONLY defeat this feature by modifying the circuit on the mother board. The remote availability has nothing to do with this feature on power on
SOURCE: Sony CDX-M850MP Remote wont work when front panel closed.
The problem is the flexible wire strip that cracked. I just had the same problem. A guy has them on auction on e bay. Type in model number and flexible replacment for search.
Fix by.
1. Unscrewing 2 the two screws that connect faceplate to motorized flip bracked. One on each side.
2. Unscrew the screws that are connected to the back plate. Plate directly behind faceplate with Blue LED.
3.Unclip backplate by sliding Deck out 1 inch. Two clips on each side.
4.Unclip the waferboard/circuit board from the back plate.
5.Remove Flexible wire band that connects the faceplate to backplate.
6.Attach new flexible wire band to deck then to face.
7. Reclip everything, Rescrew everything.
Whalah it is fixed.
Batteries are flat or incorrectly inserted
• IR transmitter window on remote, or IR receiver window on T 754 is obstructed
• T 754 front panel is in very bright sunlight or ambient light
Troubleshooting tips
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
