Question about Belkin (F5D5231-4) Router
Belkin Router F5D7633-4 (no connection) all green lights on
My laptop and PC cannot connect to the router even though all green lights are on.
We made a change last week involving Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} DMZ setting to allow the Xbox to be free from the NAT settings, however it continued to work.
    President:
  • 627 Answers
Shut down the router, after 10 seconds turn it on
Posted on Jul 24, 2009
Amber light flashing on belkin 150 router
Disconnect the ISP modem power and network / cable. Do the same with the router. Wait a few minutes and reconnect starting with modem.
Oct 08, 2012 | Belkin Connect N150 Wireless Router...
I have Belkin F5D7234-4-H V5 Router and I have one computer connected by cable and laptop connected by wireless. Computer on cable have constantly connection to the internet, but time to time laptop losing...
Go to http://setuprouter.com/router/belkin/f5d7234-4v5/login.htm and then follow the instructions following: Login to the Belkin F5D7234-4v5 Router and work your way down through the instructions.
Jun 12, 2017 | Belkin F5D7234-4 Router
Since I've connected my Belkin Play router for my Toshiba laptop, both my laptop and PC are now displaying "unable to connect to webpage. My laptop works better when I've an ethernet cable attached but I'd...
Hi ok I'm here and your problem will be fix.
If you are talking about wireless....
  1. many customers have a problems with Toshiba laptop that no means Toshiba Laptop is not Compatible with Belkin,the first think we need to do is to know what happen with your configuration.
  2. Windows XP?Vista?w7?Mac? so many questions
  3. Ok actually windows make any time security package update that make also a problems with connectivity.
  4. ok also firewall and anti virus lock the signal is we are talking wireless
  5. Now if even using cable trough router you still haven't connection means maybe there's not connection
  6. so we need to know what is the status of the light in your your router Green Yellow or Red
  7. Green there is a connection
  8. Yellow only laptop and router re connecting
  9. Red both are not connected
  10. if we talk about number (8) you mas need to clone first your mac address to get connected
  11. if the light is RED reset your router and after power cycle modem and router let 3 minutes and check if light turn Green.means connected
any questions for more explanation just ask me for a remote your PC
Sep 17, 2010 | Belkin Wireless Play Router (F7D4302)
No connection to internet through Belkin router in secure mode
check in router the option NAT, unchek some place that say limited host or something like that
Jul 28, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Belkin Wireless router problem?
Hello
Sounds like you took all the right steps.In add and remove programs at the control panel,remove your wireless card drivers and anything related to it.
Be sure to write down your wep security key from your router first.
Then remove the card,reboot,put the card back in,then reinstall the drivers.
If this does not work the wireless card may be bad.
Hope this helps.
Apr 14, 2010 | Belkin Computers & Internet
All green lights are on but laptop can't connect
With your laptop, you must in any event turn off, DHCP, START>>RUN>>services.msc enter... then scroll down to DHCP, and set to OFF, & Disabled. Check that hasn't somehow been re-enabled. You may just have to note down your settings and re-setup your router again... then using the connect to internet wizard, use that to connect to router, this will re-initialize everything.
Mar 01, 2010 | Belkin (F5D5231-4) Router
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Router connection fail
do you have internet with the modem? if you do then router is not configure correctly. If you do nothave internet ask you ISP why you are not online with the modem directly.
Sep 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I keep losing my signal intermittently on my Belkin MIMO plus wireless router it constantly goes up and down from 1.0 Mbps to 54.0 Mbps interferring with my connection. The router is connected to my...
your gonna need the belkin router amplifier for that if its too far away from the router its gonna loose signal and cause you to intermittinly loose signal and connection ./... you could also contact belkin support at www.belkin.com/support
Jul 19, 2008 | Belkin Computers & Internet
Belkin router
I had the same problem recently. After *much* frustration, here's what worked for me:
1. Unplug power to router for at least 10 seconds.
2. Connected the modem to the router, router ethernet connected to the computer (not wireless yet).
3. Typed the IP address of the router into an internet explorer window. The default is 192.168.2.1. When the page came up, it said "No connection" in big red letters in the top right corner. The goal here is to get that to change to "Connected" in green lettering...
4. Went to the "MAC Address" topic from the left hand column (it may ask for your router's password to do this -- even though I had set a password previously, it apparently lost it's memory and was back to the factory default setting of blank password).
5. Clicked "Clone" and then "Apply settings". Nothing obvious happened right away, but I think this is what fixed it for me...
6. Clicked on another heading from the left column of choices (can't remember which one). At this point, I got the green "Connected" letters in the top right corner! Success!
7. I'm having trouble re-enabling some of the security settings I had in place before (such as changing my router IP and local domain name) but for now I'm just happy to be able to connect.
Hope this helps you!
Mar 06, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D5231-4) Router Logo
685 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
