Question about Ariens 34 In. Zoom Series Riding Mower
The engine will not stay running (Ariens 34' Zoom)
Same here. I bought a brand new Zoom 34 and brought it home in the morning, went to work, returned home to cut my lawn and the engine would not stay running. It seems as if it is not getting fuel.
  • 3 Answers
A lawn mower is not much different than a car, you still need 3 things to make it run: fuel, electricity, and a spark. you say it doesnt stay running, Before trying to make any repairs, ensure that you are using the correct fuel, also make sure the fuel lines are not leaking or crimped. if the lines seem fine, check the fuel filter and/ or fuel pump. though the mower is new, they can still have faulty componets.
Posted on Aug 16, 2009
Ariens Zoom 34 will not move forward or back
suspect a damaged belt or tensioner spring for the drive belt... these units have no servicable trans-axles. or did you just remove both rear wheels ???
Nov 27, 2013 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
Ariens 34 zoom blade binds at mid-height blade
Sounds like the mower deck is lower on one side. I am having the same problem with my older tractor mower.
Jul 24, 2010 | Ariens 34 In. Zoom Series Riding Mower
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
Ariens sport zoom 1232.It stopped running,will not start unless
Small piece of dirt or debis under the fuel inlet needle causing the engine to flood out. I would clean the seat with a q-tip and a little jewlers rouge, polish the seat and install a new needle. Hope this helps. If it still leaks then replace the needle and seat due to it being damaged
Nov 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Have just bought a used ariens st1032. have no manual and wondering if unleaded gas and 10w - 40 oil will work on this machine?
assume it's 4-cycle engine. regular gas, and 10w-40 should be safe- might want to use single weight 30w oil. you won't need multi-weight if you're living in a cold climate- won't be using it in the snow! check oil level, and top-up when needed!
good luck!
Oct 24, 2009 | Ariens 34 In. Zoom Series Riding Mower
Arien 34- Blades won't engage
This mower has an electric PTO on it. I had a Scag and the electric PTO clutch went out on it. Not the cheapest things to change but easy to do yourself with some basic tools. Also, before running out and getting a new one, check the wires to it and to the engage/disengage switch. You may have a bad connection.
Oct 12, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens Zoom 34"
It will void the warantee if you start working on it..i would call the dealership and have them come out or you take it to them....Keith
Jul 04, 2009 | Ariens 34 In. Zoom Series Riding Mower
Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Jun 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Parts for Ariens Model Number FM626E
you need to get the model number from the mower body and verify that it is correct the age should not matter some hardware stores work primarily on ariens mowers hope this helps
Apr 03, 2009 | Ariens 34 In. Zoom Series Riding Mower
Brand new Ariens ST624e seized after 15 minutes of operation?
if there is oil on the sparkplug, you have blown a cylinder seal. It will need repair.
Dec 24, 2008 | Ariens 34 In. Zoom Series Riding Mower
Ariens 34 In. Zoom Series Riding Mower Logo
416 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
