Question about Bachmann Big Hauler Radio Controlled Train
My son has been left a near complete boxed set of the above but I cannot work out either where the batteries go in the engine, or if it is a rechargeable battery, where it re-charges to. There is no recharger and it may be that that is missing. It is american so the power difference may require a different UK charger. Everything else seems complete, just how to put power in the train so that it goes!!! Any help please?? Can I download an instrcution manual from anywhere? Martyn
  • 3 Answers
The batteries are located in the enginge (locomotive). They take 6 D sized batteries. At the very back there is a panel that you need to slide off to get to the battery compartment. Somtimes it may take a little manipulation to get the panel open. As for directions, Iam in the same boat with that problem. Hope this helps.
Posted on Sep 10, 2009
The AC in Rear want blow in my2002 Escalade
Yes there are two fuses and there are relays in the blower motor resistor assembly ! One fuse is located in the under hood fuse / relay box marked RR HVAC Fuse #21 30A Rear Heater, Rear Blower Relays. The other is located in the left Instrument panel fuse block marked IGN 3 10 amp. Fuse # 2. The Blower Motor Resistor Assembly - Auxiliary is In the right rear side panel above the wheel well ! The Fuse Block -Left I/P is On the lower left side of the I/P.Fuse Block - Underhood At the left side of the engine compartment near the battery .
Feb 11, 2015 | 2002 Cadillac Escalade
99 breeze won't start but has power, radio,window wiper,signal lights won't work either
Sounds like one of the cables near the battery is disconnected, or you blew a main fuse.
The battery is in the Left front fender, just above the fender you can see the cables enter the engine compartment, there wou will find several connections to inspect.
Oct 19, 2014 | 1999 Plymouth Breeze
Batteries keep dying
You have a short circuit or a bad switch somewhere near the fuse box or behind the fuse box as Ecu is also been not getting the complete voltage so kindly check the short circuit while testing from the battery wire to fusebox .Do it early before it blows your ecu.
Dec 12, 2013 | Lexus LS 400 Cars & Trucks
Toyota hilux tail lights not working. Where are the fuses hiding?
sir kindly check your owners manual for the exact location . In most of the cases , its underneath the dash board and probably near the steering wheel . It is a closed box in black colour rectangle shape . The box can be unclipped to open . The fuse diagram will be inside the cover of fuse box . There is a fuse box toward the left side of the engine inside the Bonnet also check it also . The light fuses are within the car as i mentioned above itself
Jun 05, 2011 | Toyota Pickup Cars & Trucks
My tony hawk SHRED board controller will not calibrate.. any suggestions?
I have been trying since Dec. 23, 2010 to calibrate this board; this is my son's... got it for him for his 8th birthday........... finally! tonight! i GOT it, after trying the batteries, moved furniture and got out the measuring tape, the repositioning of the wii, dongle, and sensor bar, directv box off, lights off, and left for hrs... nothing worked UNTIL i did all of the above AND placed a light colored sheet under the board, completely laid out, covering the dark maroon carpeting AND it worked the FIRST TIME.... after numerous attempts in the past 15 days. my son is gonna be THRILLED when he wakes up tomorrow.....
Dec 19, 2010 | Activision Tony Hawk: Shred
My cigerate lighter does not work on my 2001 ford Taurus station wagon where is the fuse block
There are 2 fuse boxes / fuse panels in nearly every Ford product: one directly above the driver's left foot (when the driver is actually sitting in the driver's seat). The other is inside the engine compartment, on the right side - contains high current fuses.
Aug 09, 2010 | Ford Taurus Cars & Trucks
Fuse box location
hope this helps
Apr 24, 2010 | 2000 Ford Taurus
Looking for the location of the fuse box on a 1998 ford windstar to replace a left turn fuse
If you have right turn signals that work it will not be a fuse as 1 fuse controls the whole circuit.
I would start by checking the bulbs and then the turn signal stalk itself.
There is extensive coverage of fuses and the circuits each one protects Owners Manual.
See "Related Questions" below for sources of free online Owners Manuals for 1996+ Ford & Mercury products.
Checking & Changing A Fuse Inside the fusebox cover is a small white plastic tool for pulling fuses out.
Inspect the center section of the fuse to determine if it has 'blown' - it will be obvious if the metal strip has melted.
Insert a replacement fuse of the same color / amperage protection by simply pressing it into the fuse-slot.
Checking a fuse Generally, if a fuse is 'blown' you can tell by looking at the fuse. Look at the wire looking thing in the top on the fuse. It'll look kind of broken or burned or just otherwise messed up. If you're not sure what a good fuse looks like, go to an auto store and look at a new fuse. Then look at your fuses and compare appearances.
Getting the engine compartment Power Distribution box cover off There are actually two separate covers. One is for the circuit breakers and one for the fuses. There's a tab in the center that you squeeze together and it pops off. In the cover you'll find spare fuses and a puller. If you still need to get the breaker cover off, there's a tab on the corner marked "lift". With the other cover removed, you can then unsnap the tab and wiggle it out.
Answer Go to the dealer service dept and ask them to photocopy the diagram out of their service manual for you. They should do this for you with no problem.
Answer If you want an owners manual try MOTORLIT.COM.
Answer Under the dash just to the left of the steering column.
Underneath the drivers side kick-board / panel underneath the steering column.
One fuse box is located under the hood by the battery. Another is under the left side of the dash. Carl
Not real sure for this model but I think there is a fuse box by the battery under the hood and another one under the left side of the dash. Carl
power fuses are next to battery in a black looking contaner there is a lid that has to be removed. the regular fuses are located underneaath the dashboard on the drivers side above your left foot... if you are sitting in the van
there are two fuse boxes, one is in the engine compartmente near de battery, the other one is under de driver side near the steering column.
It depends on the fuse. Most of the fuses in use today are small plug-in plastic devices. Simply grab them with needle nose pliers or a fusepuller and pull them straight out. They are color coded as to ampacity. There are two fuse blocks in the Windstar. One is in the engine room by the battery. The other is under the left side of the dash. Enjoy.... Carl
you can go to www.alldatadiy.com and you can buy a subscription for a year just for 25 bucks plus they have a lot information about your car, works pretty good for me.
Answer I think I seen it on this sight http://autorepair.about.com/cs/generalinfo/l/bl_img_ford023.htm
you have to look around. there are a lot of pages.
Click on the link below Click on Owner Guides The owners manual ( which includes the fuse box diagram ) can be viewed on-line The interior fuse panel is located under the dash panel on the left side wall near the driver side of the vehicle. it is enclosed with a black plastic cover. The power distribution unit fuse panel is a black plastic box located in the engine area near the battery, the battery should be disconnected before replacing fuses in the power distribution unit according to the owner's manual. The fuse box is located on the drivers side about half way up from the floor, it is mounted on the side and is made of black plastic roughly 4 inches wide and 6 inches high. The cover just snaps on and off.
Apr 10, 2010 | 1998 Ford Windstar
Where is the fuse box that is supposed to be under the stearing wheel
Mazda 323/MX-3/626/MX-6/Millenia/Protégé 1990-1998 Repair Guide
1994 Mazda MX-6 2.0L MFI DOHC 4cyl
Circuit Braker
A bimetal circuit breaker is located in the joint box, which is just above the interior fuse panel. This circuit breaker protects the rear window defrost circuit and is the plug-in type.
Fuses
The main fuse block is located inside the left side of the engine compartment near the battery. There is also an interior fuse panel located just above the left side kick panel.
Fuses Replacement
CAUTION Never replace a blown fuse with one of a higher rating. Severe damage to the vehicle, electrical harness and components, as well as personal injury or even death could occur.
Main Fuse Block
(see Figure 1)
  1. Disconnect the negative battery cable.
Fig. 1: Remove the fuse box cover, located in the engine compartment, to access the main fuses for the vehicle
  1. Unhook the lock tab from the main fuse block cover and open the cover.
  2. Pull the fuse from the main fuse holder.
  3. Installation is the reverse of the removal procedure.
Interior Fuse Panel
The interior fuses simply unplug from the fuse panel. Use the fuse puller tool provided with your car to remove fuses from the panel. The tool is located on the back of the interior fuse panel cover.
Relay
The main relay box is located on the upper left-hand side of the firewall (bulkhead). There is also a relay box mounted inside the vehicle under the left side of the instrument panel.
Relay Replacement
  2. If replacing a relay at the main relay box, disconnect the electrical connector and slide the relay from its mounting bracket.
  3. If replacing a relay at the interior relay box, simply unplug the relay.
  4. Installation is the reverse of the removal procedure.
Fig. 1: Typical fuse box and panel locations and configurations
I hope help you with this (remember rated this help) Good luck.
Sep 28, 2009 | 1994 Mazda MX-6
Where are the fuses located inside the 91 Toyota Camry?
There are three fuse panels. The passenger side fuse box is right behind the passenger side kick panel. The main fuse and relay block is near the battery in the engine compartment.The Instrument panel fuse box is on the left side of the steering column on the dashboard.
Sep 25, 2009 | 1991 Toyota Camry
Bachmann Big Hauler Radio Controlled Train Logo
608 people viewed this question
Top Bachmann Crafts & Hobbies Experts
freddyfox
J.D. Browning
J.D. Browning
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
