Question about Maytag PTB1954GR Top Freezer Refrigerator
Freezer is working
The freezer is working but refrigerator is not getting cold. Fan is working.
    President:
  • 744 Answers
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! Mike
Posted on Jul 24, 2009
Freezer works but refrigerator doesn't get cold
There is a flapper mechanism in the freezer that directs the flow of cold freezer air into refrig compartment. If it is not working properly and is in the closed position the refrigerator will be much warmer than normal. Also make sure that the evaporator fan in freezer is running - it pushes the air out.
Sep 02, 2015 | Dometic Refrigerators
My refrigerator is not getting cold
Is the freezer freezing? Do you hear a fan motor running inside the freezer? If the freezer fan is working and the freezer is still getting cold, do you see allot of frost on the back wall of the freezer?
Freezer not cooling at all - t-stat or compressor would be where to check next
No fan running in freezer and freezer is cold - bad evaporator fan motor.
If fan is running and you have heavy frost on the back wall of freezer - unit is not defrosting. could be defrost timer or defrost t-stat
Mar 12, 2013 | Amana Refrigerators
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerator is not getting cold although the freezer appears to be working fine
can you hear the evaporator fan motor running in the freezer? this fan motor pushes the cold air from the freezer to the food section to keep it cold. you may have to replace the evap. fan motor. also, check for any kind of ice build up around the evap fan motor.
Oct 11, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Freezxer dosn't work
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Nov 23, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Maytag PTB1954GR Top Freezer Refrigerator Logo
157 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
