Question about Xerox Office Equipment & Supplies
I have a Xerox XD125F Workcentre. The J2 toner
I have a Xerox XD125F Workcentre. The J2 toner drum light came on. After replacing the drum the light still remains. How do I reset the copier after replacing the drum?
  • 4 Answers
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Posted on Jun 26, 2010
    President:
  • Xerox Master
  • 990 Answers
Hello sir; After you replace drum, you have to reset the drum count, the procedure as follow;
press "clear" "exposure" "clear" "exposure" then enter 24 press "start", machine will back to normal. good luck.
Posted on Jul 24, 2009
Xerox WorkCentre XD125F- need manual
You can get the spec sheet and the user's guide as PDFs here:
http://www.support.xerox.com/go/results.asp?prodID=XD125f&Xlang=en_US&Xcntry=USA&Xtype=docs&prodName=WorkCentre%20XD125f%20Digital%20Copier%20-%20Laser%20Printer
The spec sheet has the toner cartridge and drum cartridge part numbers (listed as Supplies)
Toner Cartridge 6R914;
Drum Cartridge 13R551
When copier has printed about 18,000 pages the J2 drum cartridge light will come on. The unit will print about another 1,000 pages before the unit stops working until the drum cartridge is replaced.
I hope this helps.
Apr 14, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
Getting J2 on the screen copier won't work
That means the drum cartridge has reached the end of its life.
You can replace the drum unit or the chip on back.
You can google a business called "the parts drop."
They should have both.
Jan 19, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
J2 ERROR
Replace the Drum Cartridge.
Jun 26, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
J2 Error on XD125F
With that machine, what frequently happens is the flag in the drum unit falls down during shipping and does not swipe the drum replacement switch.
You can do one of 2 things, Exchange the drum cartridge or, on the front of the cartridge you have to remove the green cover, Remove the clip and pop off the gear cluster. Then look at the one gear in particular that has a flag like protrusion. Rotate it so that it stops up and to the right, so that when you place the drum back into the machine it can rotate down and hit the switch that tells the machine you replaced the drum.
That flag only runs a half turn, one time at install. And if it has fallen in shipping hte J2 will not clear.
That is what has happened. It is pretty common.
Sep 17, 2008 | Xerox WorkCentre XD130DF Laser Printer
We have a xerox 2520, that has a J2 error code. We can't fix a service rep locally.
1. turn off XD125f
2. Turn on
if not try again
6. turn off
Sep 16, 2008 | Xerox Office Equipment & Supplies
Printer Stopped
J2 is the drum cartridge, or some people call it print cartridge has reached the end of its life.
J1 is the toner cartridge, J2 is the drum.
Jul 17, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
XEROX WORKCENTRE XL2120
J2 means the drum cartridge needs replaced.
Its next to the toner.
Jul 14, 2008 | Xerox WorkCentre XL2120 Laser Printer
Xerox copier
J messages on Xerox machines always refer to toner or drum.Is the toner out , you could give it a shake (might be a good idea to go outside!) Sometimes it will run out without displaying a message(Pyramid of dots for out of toner) Drum end of life usually comes up with a crossed circle or similar .If all OK you could have a blocked toner supply auger or lumps caused by storing toner in sunlight, both would require the toner system being vacuumed out.
Nov 26, 2007 | Kyocera RI-3530 Black and White Copier
Xerox Workcentre XD125f problem
Does it keep showing that after you replaced the toner cartridge?
Aug 17, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
358 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
