Question about Siemens CF110 Cellular Phone
Benqsiemens E61 CELLPHONE
I can not set up a ringtone. It gives me message unsupported format? When I get incoming call it just vibrates.
  • 71 Answers
You have to convert your ring tone in mp3 file and then it will play it
Posted on Jul 24, 2009
How do I get a ringtone instead of vibration on my LG530G cellphone?
try going into settings and change the method from vibration back to ring tone
Sep 06, 2015 | LG 5350 37V 1550mAh Extended Life Liion...
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
Message Alert Repetition
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Samsung wave no message sound
I have seen this one or two times with a few of my Samsungs but the only way I have found to fix it is to power off the phone and power it back on. If that doesn't work you might try going through the phone settings and un-checking/rechecking and sliding all possible sound options to make sure nothing is coincidentally set for this.
Mar 28, 2012 | Samsung Wave S8500 Smartphone
How do i install a new ringtone for incoming messages on a samsung s5600 mobile.
Hi, you have to download new ringtones for you phone by browsing with the phone, downloading and installing the ringtone and you follow the steps below to use your desired ringtone..
  • Go to menu display and light and press for widget.
  • Tick sound settings box and click out to main screen.
  • Pull across the little tap at the side of the screen and press the phone icon.
  • At the top right hand side click the little box and scroll down to New message.
  • You will see a box containing Message alert type and another box with Message alert tone.
  • Just select a tone or go search for one by selecting sounds.
Hope this helps.
Apr 15, 2011 | Samsung S5600 Unlocked Cellphone with...
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Change Ringtone Automatically when charging
The BlackBerry gives few profiles to choose from; e.g. Normal, Loud, Quiet, Vibrate.... my recommendation would be to configure each profile separately and just enable/disable the profile you like when you enter/exit your car...
The phone itself is not capable to switching the profile on its own once it is plugged in to your car charger...
Hope this was helpful...
Nov 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Ringtone for incoming text??
Most samsung models dont let you use ringtones as txt alert. Soz.
May 21, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Nov 19, 2008 | Nokia 3120 Cellular Phone
Siemens CF110 Cellular Phone Logo
305 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Yoav Shilon
Yoav Shilon
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
