Carrier air unit kicking on and off within 2 seconds, continually
I have a carrier model FA4ANF04200 central air unit with 38xcc42-3 compressor. It was installed in 2004. I am hearing the AC unit kick on and off several times at night, almost like it has a short. In order to prevent damage I have been turning off the cooling on the thermostat. The fan keeps blowing. I have an auto thermastat hooked up to regulate the temperature. Any ideas of where to start? Did not get a manual when installed and unable to locate the manual on the net.
  • 22 Answers
Hello friend, from your post I am assuming that when the unit is running it is cooling? Any electrical storms in the area lately? If you are home when you hear one approaching it is always a good ideal to turn off the unit until the storm has passed. One thing that you can check is the low voltage control wires where they make their connection to the unit. Shut the power off to the furnace and the condenser and then take the wire nuts off that are making those low voltage connections and make sure they are connected good. You also at the same time can take off the thermostat from the wall and check it's connections. If no problems there then I would call a service co. before it get's worse. Hope this helps 2rns4u <*{{{>(
Posted on Jul 24, 2009
Carrier model 38tdb air conditioning unit kicks out the 40 amp breaker. Also moisture under compressor unit outside. What is problem?
What breaker? The breaker for the condenser? Likely have a compressor shorted to ground or drawing locked rotor amps. Easiest way to tell is make sure breaker off, unhook compressor wires from contactor. Turn on breaker and turn on machine. If the breaker does not trip, obviously problem with compressor
Jul 14, 2016 | Carrier Heating & Cooling
What model Air Conditioner compressor has a 4 piston configuration?
nothing in the small unit size ( 32.000 btu)
only company that made larger compressors were Carrier and they were for cold storage units
go google and type in---air condition compressors and see what site s show up
as you have not bothered to specify what system or application you have , it is difficult to be more precise
Feb 14, 2016 | Heating & Cooling
The fan on my Carrier central air conditioner a/c model 38ER036300 does not move when the compressor kicks on. The unit will heat up and then will start. It also will start when I give it a small push. The...
Hello YES the blades have to move freely.If it has oil ports look on the side of the motor for a YELLOW plastic plug/cap there are 2 one at the top & one at the bottom.Pry them off/loosen with a small screwdriver & squirt #20 oil in the holes.3 in one oil will work also.If there are no plugs it is factory sealed & it is new motor time.
Aug 28, 2010 | Carrier 38BRC060 Air Conditioner
Carrrier Central heat and air. Model 38CKC042300, Serial 4101E7590, Prosuct 38CKC042_ _ _301_ _. Woke up to hot house. Fan running but compressor outside isn't. Cool on flashing in thermostat window when I...
Unfortunately no, this is one of three things.
1. Compressor is worn and is starting to pull to many amps to operate. Can possibly be fixed by putting a hard start kit on the unit, but will have to be done by a technician.
2. Compressor has an internal short and will have to be replaced.
3. Fuses bad or under sized. Max fuse size is stated on information plate on outside unit.
Sorry to hear about your troubles and hope you can get it fixed soon!
Aug 15, 2010 | Carrier 38CKC042 Air Conditioner
Cooling problem with my ac.
The start capacitor may be the problem. Is your AC a central unit or window unit? Whats the model and make? If a window unit it could also be the thermostat is defective or too close to evaporator fins. Dirt on the condenser outside can cause the motor to heat up to the point it shuts down to cool the internal overload. Let me Know, Sea Breeze
May 18, 2009 | Carrier Heating & Cooling
Carrier central ac high efficiency
usually capacitor,burnt wires or bad compressor.kill the power and check the terminals at the compressor.they have been known to burn off if the connection is loose.
Sep 06, 2008 | Carrier 38CKC042 Air Conditioner
Carrier central ac model 38EN036300
If you have an electronic thermostat, they can short out, leaving the compressor running. Also, the big relay that runs the compressor can get its contacts welded together. See if the contacts are stuck closed.
Jul 27, 2008 | Carrier 38CKC036 Air Conditioner
Central Air Conditioner
Turn the power to the indoor unit off. Remove the cover where the fan is. Feel the motor of the fan. If it is very hot the bearings have likely gone out. If the fan is cool to the touch I would call a service company because you likely have an electrical problem that will require some training to solve.
Jul 09, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
175 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
