Question about Emerson Televison & Video
Can I replace the 125volt 4 amp with a 250volt 5 amp
  • 67 Answers
The answer is no. The bulb will not lightup.
Posted on Jul 24, 2009
I have a model 6162 norcold refrigerator in my camper. We use to travel with it but this year we have a permanent site. Plugged it in and it auto switched to run on gas and it runs perfectly fine on gas....
could be that due to bad roads, you damageg one of the wires, that is a direct short that blows the fuse, take the fridge out and check your wires
May 09, 2017 | Cars & Trucks
The 6.3 amp 125volt fuse blew. Do you know what the part number is so I can order a new fuse? Thanks, Fred
a known manufacturer is BUSSMAN fuse BK/GMC-6.3A
you can find this brand everywhere. just make sure you do NOT use anything higher voltage.
good luck
Mar 24, 2011 | Sony STR-DE685 Receiver
Need wiring diagram for electric cord attachment
Wiring Option1: Wiring Option2: OLDER HOMES AND ELECTRIC DRYERS NEWER HOMES AND ELECTRIC DRYERS range%203-wire_cord_connection_250.jpg range%204-wire_cord_connection_250.jpg
NEMA 10-30R 30AMP-125/250VOLT
NEMA 14-30 30AMP-125/250VOLT
This system can be configured depending on what your wiring situation is.
For example you could be faced with the following situations:
converting an old 3-wire outlet
to a new electric dryer
converting a new 4-wire outlet
to an old electric dryer
Feb 01, 2011 | Amana ALE643RB Electric Dryer
Can I plug in a 230V 15 amp window air into my 20 amp wall outlet or is the 20 amp wall outlet not giving me enough volts. if not then how can I do this without wiring up a new circuit/outlet?
Hi, the amps would be OK, but you have to have a 230 volt outlet to plug it into, or it will not run. There is no other way to do this unless you run a 230 volt line over to the window unit. You can do this from the outside of the house. This is all you can do unless you move the a/c to where you have a 230 volt plug, and I don't think you want that. This is the only way I am sorry to say.
Sincerely,
Shastalaker7
Jun 12, 2010 | Maytag M6W12W7A Air Conditioner
Red light blinks 5 times!!
C509 .47uF Mylar 250Volt. Replace this cap, this should restore power.
Jun 04, 2009 | Panasonic PT-53WX53 53" Rear Projection...
My kenwood compact disk payer rxd-a53 shut off now it keeps click
Your problem is caused by a blown fuse on the main board 6.3amp 125volt time delay fuse replace with the exact same type. The reason the fuse blew is most likely because they is a problem with the amp.
I suspect one of the finals is blown 2SD2560 or 2SB1647. Open the case and with the power unplugged replace the fuse, next unplug the 4pin connector from the amplifier board 3 black wires and one red.
now plug in the RXD-A53 and turn it on. you should now have the display working and no clicking.
unplug it from the wall and reconnect the 4 pin connector and now plug it back in and turn it on if the fuse blows again take it to a qualified service technician, the above noted output transistors will run you about 6 bucks a piece they are 4 of them 2 of each for each channel plus labor.
Mar 02, 2009 | JBL On Stage Micro Speaker Dock for Apple...
I can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Jan 11, 2008 | Panasonic CT-36SX12 36" TV
No sound out of any speaker input
i have the same ******* problem
Jan 03, 2008 | Sony STR-DE845 Receiver
Televison & Video Logo
49 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
