Question about Panasonic DMR-E85H DVD Recorder
When I switch on the recorder goes into SELF Check for 10 to 20 minutes
    Problem Solver:
  • 7 Answers
Try replacing bad capacitors on the power supplycard. See http://vassfamily.net/projects/DMRE85H/dmre85h.html
Good luck.
Alsofor those interested, I found the "commands" listed onhttp://www.dxcc.com/dmr-e85h.htm useful when operating the DMR-e85h tocorrect problems.
Posted on Jul 31, 2009
Self check
Try a hard reset: Unplug the recorder from the power socket and TV, wait about 5 minutes and replug into the power socket and TV.
Please try that first and let me know how it goes..
May 22, 2008 | Panasonic DMR-E55 DVD Recorder
I have a Tv Philips model 32PW6506/01 few minutes after that is between 10 and 20 minutes go stand by, then if I press p + start and after 10,20 minutes and goes into standby ...If anyone knows about...
Good day!
Usually that problem is cause of the failing capacitors on the power supply section.
You have to do is open the back cover of your TV and look for the actual image of the capacitor with in the power supply section if it is leak/bulged on the top.Please replaced it with the same type,ratings and value.
Thank you and good luck.
May 08, 2011 | Philips 32PW6506 32" TV
Panasonic DMR-E55 gives frequently "SELF CHECK". Sometimes it working ok but when i try to erase some recordings he goes to SELF CHECK. The problem came very slowly.Is this a problem with the power...
in short "yes". the switching regulator IC (component found on heatsink "cooks" because the heatsink is not big enough).
start with checking power supply capacitors for bulging tops or electronic leakage (preferably using ESR meter) & fitting bigger heatsink. If problem persists then replace switching regulator IC
Sep 23, 2010 | Panasonic DMR-E55 DVD Recorder
Ihave dmr-e55 it records advd for 5 minutes and it goes to self check
1) Press and keep [POWER] button on the unit for more than 10 seconds
to turn off the power of the unit.
2) Unplug power cord and wait for approx. 1 minute.
3) Plug power cord in.
4) The display shows [RECOVER] or [SELF CHECK] and it becomes under
recovery. Wait till the message on display disappears.
*When the unit does not recover after taking above procedures (1 to
4), it is needed to be checked and repaired.
Mar 25, 2010 | Panasonic DMR-E55 DVD Recorder
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My machine goes into self checking mode and gets stuck.
If it's going into self-checking then either there is a problem with the drawer deck mechanism not being able to communicate with the logic board, hence the reason it stays in the self check. Contact your local Panasonis dealer to arrange a service engineer to perform a software update on the recorder as your current software could either be an older version or has been corrupted & needs to be updated.
Sep 05, 2009 | Panasonic DMR-E55 DVD Recorder
Player shutdown and then go to self check
unit goes in to self checking over and over dvd can not be ejected and will not function at all?
Aug 05, 2009 | Panasonic DMR-E55 DVD Recorder
Self check will not stop
Hi
This is very common, please see my earlier posting which will tell you how to repair it, by clicking the link.
DMR E55 Self Checking Repair
Best wishes
Mar 21, 2009 | Panasonic DMR-E55 DVD Recorder
Stays in self check mode
If self check keeps going after 1 minute unplug machine and open top cover remove 4 screws that hold the recorder top cover remove disk reinsert screws and plug in see what happens.
Most of the time a small scratch or fingerprint on recorded disk cause these units to lock up
Jul 18, 2008 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
371 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
