Network Point? for AMD Athlon XP 1900+
Hi, I am trying to locate my network point on my pc. I have a AMD Athlon XP 1900+ 1.60GHz I am just looking to hard. Hope someone could help.
  • Skip2114 Jul 25, 2009
    Hi louislevel_2,
    Thanks for the quick response. I have had another look for my network port at the back of my base unit to no avail. I know what it should look like - just not sure what to do next if I have not got one. Still none the wiser really. I have contacted my broadband supplier to ask for help. Feel a bit of a muppet at the mo. Basically, I've changed my type of broadband connection and am trying to link up the new equipment. I get to the part where it says plug in the network cable in the network port and get stuck cos can't find it. The other alternative is to do this wireless and my main pc is not wireless enabled. I am sure I will get this sorted in the end. Will keep you posted. In the meantime - thanx v much.
  • 374 Answers
click start,click control panel,on control panel find and click network connections,on network connection right click local area connection and click status or properties.then you can find what tehe staus of your connection,if this was disable click enable so that your network will function to connect to internet or other computer,also check the setting on this.You can check also your network device on device maneger,on control panel,click system
click harware on system properties,click devices,on devices right click network adapter ,and properties,check the driver of your network,if no driver up date or download it on internet,by typing the brand of your wetwork on internet research box and it will find it for you,hope this can help you,best regards
Posted on Jul 24, 2009
Ga3400 reports 384 meg of ram
hello, that sounds right because the system you are reffering to is an "Everex IMPACT GA3400" by default this 512mb of RAM but 128mb of it is shared for your video card hence leaving you with 384mb.
below are specs for your sysem:
Processor
  • 1 x AMD Athlon 64 3400+ 2.2GHz
    Bus Speed
  • 1600MHz
    Cache
  • 1MB L2
  • Memory
    Standard Memory
  • 512MB
    Maximum Memory
  • 2GB
    Memory Technology
  • DDR SDRAM
  • Storage
    Hard Drive
  • 120GB Ultra ATA 7200 rpm
    Optical Drive
  • DVD-Writer (Double-layer) - DVD?R/?RW
  • Controllers
    Controller
  • Ultra ATA
  • Display & Graphics
  • Graphics Controller
  • nVIDIA GeForce 6100
  • Audio
    Sound Card
  • Included
    Speakers
  • Included
  • Network & Communication
    Network
  • 10/100Mbps IEEE 802.3u Fast Ethernet
    Modem
  • 56Kbps Data/Fax Modem Integrated
  • I/O Expansions
    Expansion Slots
  • Flash Memory Card (1 Total)
  • Input Devices
    Keyboard
  • Included
    Pointing Device
  • Included
  • Interfaces/Ports
    Ports
  • 1 x Audio Line Out
  • 1 x Microphone/Line-in
  • 6 x 4-pin Type A USB 2.0 - USB
  • RJ-45 Network
  • 1 x RJ-11 Modem
  • 1 x VGA
  • 1 x 6-pin mini-DIN (PS/2) Mouse
  • 1 x 6-pin mini-DIN (PS/2) Keyboard
  • 1 x IEEE 1284 Parallel
  • Software
    Operating System
  • Windows XP Home with SP2
    Software Included
  • CyberLink Power DVD
  • CyberLink Power2Go
  • Norton Internet Security
  • i would recommend that you visit crucial.com or newegg.com for memory upgrade which will improve your new PC's experince.
    hope this helps,
    good luck,
    regards,
    Amar Sondhi
    Dec 06, 2009 | Everex GA3400 Refurbished AMD Desktop...
    Had a virus. used disk to restore. network adapter didn't install
    U WILL HAVE TO UNINSTALL THE FIRST PROGRAM THEN REBOOT AND TRY INSTALLING AGAIN. check your network card,maybe the driver is missing but id uninstall and do it again make sure disk is clean no scratches.
    Oct 29, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
    Tried to install sp37394 on my HP amd processor
    You can try installing SP3 in safe mode, so that It doesn't conflict with any application software.
    It should get installed successfully and problems should be fixed.
    (Restart PC and keep tapping F8 to get advanced menu options and choose safe mode from there)
    Let me know if you need any more help !
    Thanks !
    Oct 09, 2009 | HP Compaq Presario SR1620NX...
    Windows xp wont connect to internet
    Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
    Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
    p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
    If it is not working, check the default gateway address on working computer and use it instead.
    Feb 10, 2009 | D-Link AirPlus DI-524 Wireless Router
    Nec 17'' multisync lcd monitor not working properly
    What is the problem? Did you try plugging it into another working computer?
    Mar 03, 2017 | NEC AccuSync LCD71VM 17" LCD Monitor
    Can't install a driver
    i've lost my driver cd for my asus wl -167g, can i download it for free?
    Apr 03, 2008 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
    L7VMM2 Motherboard driver
    Possibly using the free program below you will be able to tell us more info on your computer
    Belarc Advisor - Free Personal PC Audit (Version 7.2a)
    http://www.belarc.com/free_download.html
    Jan 09, 2008 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
    Processor
    hi, from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported. Recommended Speeds: AMD Athlon? XP 2600+ (266 FSB) AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2400+ (266 FSB) AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2200+ (266 FSB) AMD Athlon? XP 2100+ (266 FSB) Model 8 AMD Athlon? XP 2100+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 8 AMD Athlon? XP 2000+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache all the best.. sreejith
    Jul 16, 2007 | Compaq Athlon XP 2000+ , 1.67 GHz...
    Computers & Internet Logo
    87 people viewed this question
    David Payne
    David Payne
