Question about Seagate (ST3160827AS) 160 GB Hard Drive
Hard Drive not recognized
I've had this hard drive for a year now (and BTW also experienced the 137GB only formatting issue previously mentioned). The drive was getting close to full and now it is no longer recognized. I vaguely remember the Seagate formatting sw saying something about if formatted a certain way there could be problems when the drive gets full. I thought I avoided this. Anyway, my daughter's 2nd year of life is on this drive so my neck is on the line here.
  • 32 Answers
Hi eric,
Read this article.. I've got a lot of help from it when i had a similar problem sometime ago..Good luck!
If there's anything that you couldn't grasp then feel free to post back..
Posted on Nov 21, 2007
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137...
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Nov 02, 2011 | Acer Aspire 5002WLMi Notebook
Formatting WD SATA 500GB AAKS in larger than 137GB
The best software that can fix this problem is "Power Quest Partition Magic".It works like a dream for drives of any capacity!
Oct 11, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
I am trying to use a WDC WD80 0JD-00MSA1 scsi hard drive through a DOCKMASTER Kingwin USB connection and device driver sees it and a BELARC Advisor scan sees it but not My Computer. The drive is unused...
You mentioned that you have never formatted this hard drive. Has this been FDisk and Partitioned? If the hard drive has never been Fdisk / Partitioned / Formatted, this will not be recognized in the windows environment.
You can use DISKPART in command line to manage and partition your hard drive. After formating it in your preferred format (NTFS is recommended). Your hard drive should display properly in windows explorer.
Hope this helps.
Apr 30, 2011 | Computers & Internet
Asking me to format but when i try my computer won't do it
It reveals that previously this device was formatted by the highest operating system other than you are using. For example if one floppy formatted within windows 95 it will recognized by the other operating system but if the floppy formatted in 98 that would not recognized by the windows 95 and the operating system will ask for format as you already experienced.
Sep 23, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
My win2k adv server with sp4 finds 137gb space on a 250gb sata int hdd. how can i utilize full space where i m using 945 m/b
It's complicated to explain, but basically, you never get the full amount of space on your hard drive. For instance, a 320gb drive will always provide you with aprox. 298gb of space. However, your 137 vs 250 is a bit extreme. Is this a new hard drive? Have you made sure you have properly formatted and partitioned the drive? If this is a used drive, the previous owner may have it partitioned to use only part if the drive, so in this case I would try and format it.
Sep 05, 2009 | Western Digital Caviar 500GB Internal SATA...
I just purchased a 320 gig hard drive and when i set a partition it only shows 132 gig
Use the WD data life guard disc to partition the drive. Put the disc in, reboot the computer, and run data life guard. A screen comes up and asks if your system can recognize a partition greater than 137 gb. If your system can read larger than 137, then use the option to format one large partition.
Some OS cannot read larger than 137gb. Also some Bios have the same problem.
May 01, 2009 | Western Digital 320GB Internal Serial ATA...
Overcoming the 137GB barrier on a hard drive
*********** board have no support LBA 48bit adressing.
If you want to use so big HDD, you must to upgrade bios (for LBA 48 bit) or change motherboard for new one.
Mar 30, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
Upgrade Yamaha CDR-HD1300 hard drive - 137GB limitation
137 gig is a classic maxium harddrive limit for older BIOSes. Yamaha does not have a public firmware upgrade avalibe. since there is no way to flash the bios, it is impossible to upgrade it :-/
Feb 27, 2008 | Computers & Internet
Trying to format a 500GB HDD at full capacity
check your bios if the disk is recognized as 500gb first. if it is not recognized, update your motherboard bios. most updates are available in their manufacturers site.
Seagate (ST3160827AS) 160 GB Hard Drive Logo
59 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
