Panasonic NN-H275 1100 Watts Microwave Oven
Problem for Panasonic NN-H275 1100 Watts Microwave Oven
Fuse blows on microwave switch on
By ilyagold on Jul 24, 2009
Every time when microwave switched on the fuse blows.
Started yesterday just during normal operation.
Clarification Request
Posted by MicrowaveSvc on Jul 25, 2009
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer. If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. Please reply back with your brand and model number so we can help you.
Solution #1
posted on Jul 27, 2009
Not Rated)
dmftrucker
Rank: Guru  Kitchen Appliances  Expert
Rating: 87%, 452 votes
one of three things shorted could cause this: H.V. diode,capacitor,or the magnetron tube, take screw driver and short terminals on capacitor before touching anything inside the case, then chk resistance on capacitor should show infinite after needle settles, diode should show hi resistance one way and a lower resistance in the other direction(use the RX100 scale not the RX1) on both parts diode should not show very low resistance or it could be leaking,mag is a different story,it can be chk'd but in a different way
Was this helpful?
Yes
No
Popular Solutions for Panasonic NN-H275 1100 Watts
Questions and Unsolved Problems for Panasonic NN-H275 1100 Watts
Do you recommend Panasonic NN-H275 1100 Watts Microwave Oven?
Answer
Answer
keypad stops working after few minutes. after waiting for while it starts to work again.
Answer
can you not invert blower motors to fume upward and not through the back
Answer
I have a Panasonic NN-SD986S microwave oven. Shortly after a power outage, I noticed the following:... (More)
Answer
The Microswave is running in demo mode. It appears as it is running with the light on and turn tabel... (More)
Describe your Microwave Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Oven Experts
Top Small Appliance Repairmen
in , IL
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
