Question about George Foreman GR31SB Indoor Grill
My gr31sb grill wont heat up, i found the microtemp g4 thermal fuse is bad by by passing it and the grill works. how do i get a new fuse?
Don't know if this helps but Radio Shack has Microtemp 10 amp G4A00 Tf 144c (144 deg Celcius) Thermal Fuses. These are the ones with the little red conical end on them. Under $2 each. I needed one to put in my toaster oven. Couldn't find the small metal clips to attach it to the wiring though. Since it is very diffucult to solder these without damaging the fuse, I'll have to recycle the old clips.
Posted on Jun 20, 2010
Unit stopped in middle of cycle tested to microtemp fuse nothing across?
On that thermal(microtemp) fuse if you found it to be open that is going to be the problem it should be closed with zero ohms resistiance
Gene
Aug 15, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
TRYING TO FIND THERMAL FUSE. MICROTEMP G4A00 TF216C
Unfortunately, YoTeach's initial solution is in error, I believe. YoTeach mentions that typical temps for brewing water are less than 200F, and THAT seems OK, from a couple of quick searches.
However, the component that is being replaced is not necessarily working at the same temperature as the water needs to be.
The Microtemp G4A00 series has lots of temperatures, and the TF216C means, AFAIK, that Tf is 216C(elsius). See, for example, the datasheet here:
http://www.farnell.com/datasheets/625786.pdf
Tf is the temperature at which fuse opens. So, the person ACTUALLY needs a thermal fuse that opens (breaks the connection) at 216C.
Therefore, either of the two fuse temperatures mentioned: 128 & 140C, would open too soon: i.e. at too LOW a temperature.
While 216C may seem like a high temperature (420F), for the fuse to open, the thermal fuse is often very near the heating element. For comparison, I have a Gevalia CM500 coffee pot, and the thermal fuses in my particular unit are Microtemp G4A00 184C- which is about 363F.
If anyone thinks I am in error on this, please feel free to contact me: jim underscore peak at Hotmail dot com - and I'll be happy to correct this post.
Aug 29, 2009 | Krups Small Appliances Espresso Machine
Krups km7005 water not heating nor hot plate
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbech, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Aug 01, 2009 | Krups Small Appliances Espresso Machine
Grinds but won't brew
If your plate is not heating, no water will flow. This seems to be a common problem with this rig. So far, I've helped 13 people on this site with exactly the same problem ... all the lights are on, but no heat on the plate and no dripping water.
The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz
Jun 19, 2009 | Krups KM7000
Krups model KM7005 water wont heat
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Jun 02, 2009 | Krups Small Appliances Espresso Machine
Apr 10, 2009 | Krups Coffee Makers & Espresso Machines
I'm having some of the same problems
2001 blower (Air Or Heat) only operates on high
Behind the glove compartment right hand dash( just remove glove box liner) is a metal box of resistors which select through the Heater /AC switch called the heater control unit. Inside there is a thermal control diode/resistor
Small silver cylinder which can be replaced (or bypased because it's amperage rating is low)
Or Replace the whole heater control unit Plugs in
Billmol@msn.com
Sep 10, 2008 | 2001 Dodge Caravan
Heat
I found one on e-bay .. At the following link ,and my temp on my coffee maker (( Black&decker )) was at 216 C but I plan to up it du to the fact that there is a total of 3 thermal fuses in there . Hope this helps !!!!!!!!!
Rick @ www.antler-lights.com
http://cgi.ebay.com/Microtemp-Thermal-Fuse-You-specify-temp-required_W0QQitemZ140036901378QQihZ004QQcategoryZ66753QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Sep 23, 2007 | Faberware FCP240 Coffee Maker
Grill Stopped working
I am having this exact same problem. Did you ever get yours taken care of? I was going to take mine apart and look for a fuse...
Sep 24, 2006 | George Foreman G5 Indoor Grill
George Foreman GR31SB Indoor Grill Logo
892 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
