Question about Sony PS3 40GB Best Sellers Bundle Console
Ps3 hot warning and tuns of in 2 minutes
It warns, blinks red light then turns of itself.
    Problem Solver:
  • 11 Answers
Sounds like you have either played your playstation to much and it has overheated or your hard drive is messed up, easy way of checking, turn your ps3 on by holding the button on the ps3 but dont take your finger off, it should beep once, then beep again, then it should do a double beep, if this works a menu should come up, do number two, unfortunately all saved data KAPUT, gone, but the good thing is that your ps3 will be fine and working again in no time free of cost my freind, hope this helped
Posted on Jul 24, 2009
PS3 turns on then immediately beeps and turns off with a blinking red light.
Hello there stock380
If you have the red blinking light then you have the RED light of death AKA the RLOD.
The light is a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the RLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click Here For The PS3 Manual which has helped so many people like you.
Good luck
Best regards
Peter
Sep 15, 2011 | Sony Playstation 3 (PS3) Console
I have the 40 gig ps3 console. Today, I was in the middle of a game (it had only been turned on for about 20 minutes) when my console shut down and the red light started flashing. I turned it off and let...
Hello there Rick
Good luck
Best regards
Peter
Sep 05, 2011 | Sony Playstation 3 (PS3) Console
I have a 60gb Phat Ps3. I recently went to update it to the latest firmware and it downloaded the update fine and was running normally. Then as it was installing the update, the system shut itself off...
Hello there vincent
Good luck
Best regards
Peter
Aug 29, 2011 | Sony Playstation 3 (PS3) Console
When i turned on my ps3 it turned on green then turned yellow then started blinking red as it turned off
Hello there damian
If you have the brief flashing yellow light, then its followed by a red blinking light then you have the yellow light of death AKA the YLOD.
The lights are a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the YLOD.
Click here to know more on PS3 Fix Manuals which has helped so many people like you.
Good luck
Best regards
Peter
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
My ps3 when i go to turn on it turns green blue then yellow then blinks red what should i do ?
Hello there sfmsoberspir
Good luck
Best regards
Peter
Jul 31, 2011 | Sony Playstation 3 (PS3) Console
My problem is when i try to turn on my playstation 3 it turns on for 2 or 3 seconds then a yellow light then turns off and the red light starts blinking whats the problem
Hello there el cerroeste
Good luck
Best regards
Peter
Jul 14, 2011 | Sony Playstation 3 (PS3) Console
My ps3 turned off during a game, when you try and turn it on the light on the power switch goes green for about 3 seconds then switches off again and has a red flashing light
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning.
So in order to fix the blinking red light on your PS3 you will need to repair the connection between the HDD and the motherboard.There is actually a rather simple way that you can do this yourself; while your PS3 console is switched off, locate the hard drive enclosure on the end of your console. Remove the plastic cover plate, then using a screwdriver unscrew the hard drive itself from its socket. Carefully remove it completely, then put it back in again. Tighten the holding screw, then restart your PS3
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on everything works but in 2-5 minutes it will beep ,the screen will turn off and the blue light turns red and blinks for a while..what do i do?
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3...
PlayStation 3 red light problem, but in most cases it comes down to the system overheating. The more it overheats the more damage is created internally to the motherboard and other functioning components...
click here to download ps3 repair guide if u need
Dec 20, 2010 | Sony Playstation 3 (PS3) Console
Uncharted 2 only game that shuts down my 60 GB PS3
It seemed as if you were getting the symptoms of the "blinking red light of doom" but luckily you didn't.And VERY VERY good thinking on the back up (i never thought of it and i almost lost all my data).
I hope your new hdd runs a 5400rpm and NOT 7200rpm.
Facts:
1. A 7200rpm hdd will make system over-heat.
2. System run hotter (and in most cases of red light of doom) are HIGH graphics games such as MW2 & UNCHARTED 2.
3. Systems will last longer and cooler with an external fan that runs off its on power from a power outlet(not run off the power of the ps3!!!!)
I hope I have helped and please feel free to ask any questions GOOO UNCHARTED 2!!
Jan 05, 2010 | Sony Playstation 3 (PS3) Console
Red Blinking Light
This is a general warning code. Try switching off the power in the back of the system, waiting a minute, then switching it back on. Try turning the system back on and see if it happens again.
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Sony PS3 40GB Best Sellers Bundle Console Logo
213 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
