Question about LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP
Alarm clock not working
I set the alarm for 4h00 and Mon-Fri it works for 2 out of the 5 days when I reset the alarm it works only or the next morning and it show its set for Mon-Fri
I have an Acctim clock radio model no. 13412x. Following a recent power cut, it is 5 minutes slow. I cannot find my instruction leaflet. How do I set it to the correct time?
Model: 13412x autoset lcd clock radio alarm help line locall 0845 1207208 or (01908) 220020 mon - fri. 9.00am-4.30pm autoset lcd clock radio alarm
Feb 26, 2015 | Audio Players & Recorders
Manual download
Here's a link to the manual for your clock: http://timexaudio.com/media/uploads/product/files/T307_IB56281_07.pdf
Dual alarm settings are on page 8, and I've included the specific instructions below. I would think that the '5' setting would be for Mon. - Fri., but let me know if that's not correct. Hope this helps!
"After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week (7), weekdays only (5), or the weekend (2). Before setting the alarm, be sure that the correct date is set, as shown in the "Auto-Set" and Manual Time and Date Settings section of the manual. While the display is still flashing, press the Date/7-5-2 Button until the desired setting is shown."
Dec 17, 2013 | Timex (T307S) Clock Radio
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
Alarm function quit working for sat. and sun.
You can try to take the battery out of the clock/radio and disconnect the plug. This will allow the microprocessor to lose power and reset itself to the factory set-up. It will take about a hour to make sure its discharged. Then put the battery back in the clock/radio and see if the functions return to normal. You can go to this web link.(http://www.emersonradio.com/owners) copy and paste this web link into the address bar of the browser and it will take you to the Emerson website with all the owners manuals listed by make and model. You can find you make and model clock/radio and follow the instructions for resetting the functions. I hope this information helps you with your problem.
May 03, 2009 | Emerson Smartset Clock Radio
Smart set alarm clock - resetting instruction
First, make sure the time is set correctly – Eastern Standard Time (EST) is the default
Press the Alarm Mode button – it has options for Weekend, meaning Sat and Sun only; Weekdays (Mon-Fri), and Everyday
While holding either the ALM 1 or ALM 2 button, press up or down to set the correct wake-up time
Release ALM 1 (or 2) when you are finished
Here is a link to the manual:
http://www.emersonelectronics.ca/emerson/en/product/view/17796
-Tha Mp3 Doctor
Jan 15, 2009 | Emerson SmartSet CKS1850 Clock Radio
Changing alarm dates
Press the "alarm mode" button and change it with the + and - buittons. On the display you should see what days it will go off.
Jan 05, 2009 | Emerson SmartSet CKS1850 Clock Radio
Setting the days of the week
Sorry it took so long to give you a solution to your problem.. You can find this information on the following web page link. It will take you to the Emerson customer service web page main index for owners manuals for all the Clock/Radio products.On this page you can match the make and model of the owners manual to your make and model of Clock/Radio. You can then find the correct instructions to fix the problem with the Clock/Radio's alarms. You will need a pdf reader to read the owners manual. [http://www.emersonradio.com/owners] Copy this web page link and paste it into the address bar of your web browser and it will take you to the page of the index for the owner's manuals. If you are still having problems with the setting of the alarms, you can call the Emerson customer support at this telephone number. 1-800-909-1240. call them between the hours of 8am and 4:30pm central time USA. Give them the make and model of your Clock/Radio and ask them for assistance with your problem. I hope this information help you solve your problem with the Clock/Radio's alarms. Thank you for using FixYa and have a nice day!
May 25, 2008 | Emerson Smartset Clock Radio
Alarm set for certain days
Depress Alarm1 and hold while you then press the alarm mode button until it shows Mon throught Fri. You will then have both Alamrs set for the weekdays but you can set them to different times.
Nov 23, 2007 | Emerson Smartset Clock Radio
Timex T307S alarms
quickly press alarm 1 button to deactivate it when the radio and everyday or mon-fri icons are gone the alarm is deactivated. do the same for alarm 2 button and the sd1-4 or buz icons disappear.
Aug 09, 2007 | Timex (T307S) Clock Radio
LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Logo
96 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
