Question about Panasonic KX-T7735 Corded Phone
I'm looking for a manual for my KXT7735 phone I
I'm looking for a manual for my KXT7735 phone.
I have my extension number stuck on my display and have no idea how get the time and date back on the display. Can you help?
  • Panasonic Master
  • 2,460 Answers
The second part is easy, try pressing either * or TRANSFER until the display reads what you want. It has 3 displays. The phone instructions are particular to the phone system the phone is connected to. Try to find the Panasonic system number (the box where all the wires go) and comment back.
Carl
Posted on Jan 12, 2010
Lights keep flashing
After you connect the AC adapter the display shows Set Clock for 60 seconds and all of the extension indicators flash until you assign the extension number of your unit.
Even if you do not use the intercom, assign the number otherwise all of the extension indicators will continue flashing.
Manual here
Nov 06, 2013 | Panasonic KX-TS3282 Two-line Corded Phone
How do I have moved office and have connected my phone (panasonic kx-dt346) but I do not have an extension number, how do I program on in for my phone line? as no one can call me, but I can call out?
You have one, press the INFO button up to 3 times and your extension number will show on the display. A 6-line display phone is pretty unusual to be moving from one place to another as it's the control phone. If it was the only one in your system, MOVE IT BACK.
There is a manager's guide in the Operating Manual for your system that will give the instructions for changing extension numbers. It starts by going into manager programming (PROG **1234) and choosing program 004. In Panasonic land, you don't "swap" extenson numbers, you do a double change as in change 102 to 200 105 to 102 and 200 to 102.
Carl
Jul 04, 2011 | Panasonic KXDT346 Phone
We have lucent phones and have know ideal of how to transfer or use intercom
To use both the transfer and the intercom it,s necessary to know the extension numbers of the phones your trying to call or transfer to. To find out what the extension number is on those extensions either press feature 00 (if the extension has a display) the extension number will be displayed on the screen, if the set doesn't have a display then you can use the intercom to call a extension that does have a display. To use the intercom press one of the intercom keys below the first two line keys and enter in the extension number of the persons phone you wish to call. To transfer a call, while talking to the caller press the Transfr key(above the hold key) then the extension number of the of the persons phone you wish to call then hang up.
Oct 14, 2010 | Lucent PARTNER18 Corded Phone
I am trying to change the names displayed for each intercom number. I tried to access "admin" Feature: ** 23646, however it will not display "password" therefore I am stuck and just end up giving up. ...
Try this:
Press "Feature * * 266344"
At the password prompt, press "23646"
This should bring you to the Terminals and Sets menu and you can enter the extension number and change the Set Name.
Good Luck!
Aug 18, 2010 | NorStar M7208 Corded Phone
Our phone is a NEC DTerm 80, but looks a lot like ...
The Display can be swapped.... if you can find one.
Otherwise no programming is retained in the telephone. Swapping phones will not loose any data programed to that jack/Extension number
May 21, 2010 | NEC DTH-8D-1 Corded Phone
How do i add a new phone to an existing system? I have connected the phone & just need to assign an extension number for it so that the other phones can see the system, thank you
If you have installed it on a new extension, it already has a number. By default, on a TA-series system, the jack and extension are the same, so Jack 12 is extension 112. Quickest way is to plug the phone in and dial 0. The main phone rings and the display will give you the extension number.
To program the buttons, press PROGRAM the button and dial 1 plus the extension number. The lines should already be programmed by default, but they are 0 plus 01, 02, 03 etc. Press STORE after each button you program.
If you want to program ringing and line access differently than it already is, you need to look in the Programming Manual for the specific phone system. The Panasonic cabinet is going to be white with a silver tag or a model number stenciled or embossed on the case. Something like TA-824 or TA-624 would probably be your system model.
Carl
Dec 15, 2009 | Panasonic KX-T7730 Corded Phone
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
KX-T7730 Picking up Problem
You are on the right track but the extension number is not " 0 ". There is an extension number associated with the operator phone just as your phone may be " Extension 101". If you have a display phone have the operator call you and look at your display for her/his extension number then when their phone is ringing, pick up your handset, dial 4 plus the extension number of the operator. Let me know how it works out. .....Mitelmike
Nov 18, 2008 | Panasonic KX-TA308 Phone
Trying to add new phones to system
If you plug the phone in and it comes up with a display, then it has an extension.
To find the extension number of the phone, press Feature * 0, the display will say "Inspect" Now just press one of the intercom buttons. It will display the extension number. When done hit end.
Oct 27, 2008 | NorStar Meridian M7310 Phone
We have no designated 200 STATION
Usually the operator's extension is the programming extension. Ext 200 is the default operator's extension.
You dial 200 and it rings a phone line not an individual phone? Do you know what your extension numbers are? (Some people never use them and do not know) If you do know some or all of your extensions, what is the lowest extension number?
For me to get you specific information, it would help to know which Toshiba phone system you have. (Not a phone) The systems all program differently. Did you obtain the manual recently and are you sure it is the correct manual for your specific Toshiba system? Again, the system is not a phone and your phone's model number does not narrow it down. All the Toshiba phone systems have a name and number on the front cover. Example: "Toshiba Strata DK 280"
Nov 12, 2007 | Toshiba DKT-2020-SD telephone
Panasonic KX-T7735 Corded Phone Logo
284 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
