Question about Samsung HP-R5072 50 in. Plasma HDTV
When on HD there is a 7" band that runs across the picture that
Has snow like quality. The picture can be seen underneath. This only happens on HD so it appears to not be a cable problem.
  • 585 Answers
There are about 16 formats, about 4 are being used, compatibilty or interface issue with certain aspect/resolutions may be the issue.Check with the manufactour for a firmware update, or the issue may be within the cable box (try another box).
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 01, 2009
Bad picture on Samsung HP-R5052 50 in. Plasma HDTV
Hi there!
I suggest changing the screen , it is getting worn out
peace.
May 18, 2017 | Samsung HP-R5052 50 in. Plasma HDTV
Alternating dark and light bands
The most common cause of this is a failure in one of four earth circuit in the print head. It is not repairable
Nov 18, 2017 | Canon PIXMA MP830 All-In-One InkJet...
Gas keeps going is it worth fixing or is a new one better
I assume you mean that your screen is showing signs of stress 7 the picture quality is suffering. This would mean a replacement screen is needed & as this is very costly then it is more economical to buy a new TV instead.
Dec 01, 2009 | LG 50PG6000 50 in. HD-Ready Plasma TV
Non-hd channels only. color is washed out with
try component cables and see if you get the same results.
Oct 24, 2009 | Panasonic Televison & Video
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Sony LCD projection tv
you need to set up format and far your turn off your computer
and restart it and so cpu can pick your tv i have a 40 kdl40s2000
and i used it for my 360xbox computer vire nice pix h/d
Apr 01, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Mitsubishi WD-62825 vertical lines, blue snow, picture jumping
sounds like dm module
http://hdtvoice.com/voice/showthread.php?t=32186
Dec 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Poor picture quality on a HDTV.
When playing on HDTV's i think you have to have the HD Scart, these are £19.99 in Game and Gamestation. however i have seen them cheaper in PC World i think they where £14.99 (could have been cheaper).
I would try purchasing these connections because the standard connections are only made for normal TV's
Good luck
Mick
Nov 04, 2007 | Microsoft Xbox 360 Console
HV-175 LCD
Picture quality problems (such as lines, fuzzy image, or wrong colors)
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Check the  display issue with  a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV , switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Try to Reset the TV ( LCD) quality options. Please look in to User Guide to make the TV to factory Defaults..
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV . If the image quality problems still exists across all types of signal sources, the TV should be serviced.
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Bye.
Oct 17, 2007 | Proview HV-177 17 in. HD-Ready LCD...
Samsung HP-R5072 50 in. Plasma HDTV Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
