Heating & Cooling Logo
Henry Seese Posted on Apr 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have gree air-conditioning and its had H6 malfunction code. What should I do?
Thomas Woodburn
Level 3:
  • Heating & Co... Master 2,638 Answers
  • Posted on Apr 08, 2017
Thomas Woodburn
Level 3:
Answers
2638
Questions
Helped
1251853
Points
7008
Clean the filter. Then press on button for 5 seconds to clear code. Good Luck
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
4 Related Answers
Anonymous
  • 5 Answers
  • Posted on Jan 18, 2010
SOURCE: Gree air conditioning unit turns itself off and
i had this problem it was freezing up outside it was only a short pipe run so it was over gassed i took some out and it was fine
Anonymous
  • 1751 Answers
  • Posted on Jan 17, 2011
SOURCE: i bought gree air condition but is having short
Hi wait a moment pls your request is been proceeding..
Anonymous
  • Posted on Mar 24, 2012
SOURCE: My new gree air conditioner split system has an E1 error
My greewall mounted has a e1 prblem.how van ifixor what is the problem
ka4iup
ka4iup
  • 4062 Answers
  • Posted on Apr 01, 2015
SOURCE: Hi,I have a gree Airconditioner and its displaying H6 error,what should I do?
Google search your manufacturer make and model and the words error H6. You can find it in the search results, which will get you started.
H4 ERROR FOR GREE AC RECTIFICATION REQUIRED
Gree AC Error Code: H4
Malfunction Name: System is abnormal
A/C Status: During cooling and drying operation, compressor will stop while indoor fan will operate; During heating operation, the complete unit will stop operation.
Possible Causes: Refer to the malfunction analysis (overload, high temperature resistant)
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
New install Gree 3 head 24k btu ductless mini split. Ran for 3 weeks, then got 3 red flashes on outside unit board. Compressor does not kick on anymore. Fan units inside just blow room temp air.
It's low on refrigerant. Chances are it's on one of the flare fittings where the copper connects to the unit. You should have a one year labor warranty from the installer, should not cost you anything...3 WEEKS???
Why will the unit keep heating when the temp is above the set point?
Last month, I had this exact same issue where my temperature was not matching the set point on my heating system. I called an HVAC specialist and had it looked at. The issue turned out to be due to the fact that I always kept the heater on, instead of just on auto. These types of malfunctions seem to happen when people continually blast their heat or AC. Kelowna Heating Air Conditioning Services
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
2answers
Error code h6 my ac split electrulux?
H6 indoor unit fan stall.
Most likely a faulty fan motor but could be a faulty controller board. My money is on the fan motor which is a DC motor.
I bought gree air condition but is having short circuit
13helpful
4answers
11helpful
4answers
Gree air conditioning unit turns itself off and has an error code of HI dont know what the error codes are
Top Heating & Cooling Experts
Paul Carew
john h
