Question about Panasonic DMR-ES10 DVD Recorder
Remote control to Panasonic DVD/VCR recorder not working
Whenever I press the power button the player's display reads only "Set 1." The same thing happens when I press other major buttons on the remote. That's it.
  • 188 Answers
In the setup you can change the remote for DVD1 or 2 .Your handset must be one the same adres as the set.
Posted on Jul 24, 2009
On my Panasonic blu-Ray DMP-BD871 the screen says set 1 when I press the remote... Why is this happening I can get on to use my blu-Ray at all
Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players.
When you press a button and the display shows [ CHK REMOTE # ] or [ RC# ] or [ SET# ] it means that the DVD recorder and the remote control are not set to the same code.
To set the remote control code to that of the DVD recorder, press and hold [ ENTER ] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
May 24, 2014 | Televison & Video
Hello, my remote for my Panasonic DMR-EZ47V DVD Recorder / VCR Combo recently stopped working, and whenever I press a button on the remote, I get a message on the display as "RC1" I'm guessing...
Actually, you are sort of correct, in a sense, RC1 means remote command mode 1 (the default mode of your combo unit). There is one way you can try to fix this:
Remove the batteries from the remote, press any button on it to clear its existing memory buffer, then re-insert them or replace them with new ones. While unit is on (no DVDs or tapes in it), point the remote at it - press and hold 1 and ENTER/OK buttons together for 10 seconds, then release.
This should (in most cases) restore full remote command operation to your combo unit - if when you press a channel button on it, and the unit's front channel changes, the remote is now functioning as it is meant to.
The good news is this will constitute any workshop repairs or costs (except perhaps new batteries for the remote if required).
I hope this helps a bit.
Apr 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I entered,in error, Command mode 3 on the set up and now the remote control won't operate the machine.The display keeps showing DVD 1,how do I restore things?
Try this (works for Panasonic) - remove the batteries from the remote (as if to replace them with new ones), press any button on it to clear its buffer, then re-insert them (if they are reasonably fresh). Point remote at unit, press 1 and ENTER/OK buttons together - hold for 10 seconds, then release. This should restrore the command back from remote to the unit, and it should now fully operate. Just something to try, it may work.
Many Panasonic DVD recorders operate on the same principle; there are 3 remote command mode settings (default is DVD1) - so it's very easy to make errors in setup, but just as easy to correct.
Apr 18, 2011 | Sony RDR-VX420 DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Jun 05, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
I have a panasonic DMR-ES46V vcr/dvd HDMI i lost the instruction manuel and need to reset the remote to work agin i dont have the codes to do so all the display says is set 1 and the remote dosnt work
1) Hold The Enter Button Down On The Remote
2) Press And Hold The Numeric Button "1" For About 3-4 Seconds
3) Your Remote Is Now Reset To The Remote Control Code #1 (Default Setting)
Apr 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
Panasonic Dmr es35v VCR/dvd recorder 'Set 1' problem
Feb 10, 2009 | Panasonic DMRES15 DVD Recorder
Any button pushed on my remote control causes ''SET 1'' on display.
Hi, All you need to do is point the remote at your DVD player and hold both the number "1" and "enter" keys down for about 10 seconds. Evidently that re-sets the remote. It worked for me so good luck.
Pete
Nov 12, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Panasonic DMR-ES10 DVD Recorder Logo
299 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
