Question about Pro-Fit Pro.Fit Fo 71 02 Ford Explorer/Mercury Mountaineer Sable
1987 Mercury Sable, both turn signals not working
I cannot locate where the fuses are in this vehicle. I just bought the car 2 days ago. I need to fix the blinkers, (turn signals) ASAP. Both turn signals do not work or light up at all.
    Sergeant:
  • 202 Answers
Under the hood and under the steering wheel check if the bulbs are not burnt
Posted on Jul 24, 2009
Sable 2000 location fuse box location on vechicle
There are five locations for fuses on your vehicle.
1. Battery Junction Box (Front center of engine compartment, behind radiator)
2. Central Junction Box (Under left side of dash)
3. In-Line Fuse (In luggage compartment above left rear wheel well)
4. Relay Center Box No.1 (Under left side of dash)
5. Relay Center Box No.2 (Under left side of dash)
What, exactly, are you trying to fix?
Please review this article:
Where's The Fuse?
Jul 06, 2011 | 2000 Mercury Sable
I need to change my turning signal fuse in a 2000 mercury sable but cannot locate the fuse relay. Can anyone tell me where it is located. I have no turning signals right now!
For 2000 Mercury Sable 3.0L EFI DOHC 6cyl the Flasher is located on front seating area, driver side, under dash, mounted in junction block.
Passenger compartment fuse panel
The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the panel cover to access the fuses. To remove a fuse use the fuse puller tool provided on the fuse panel cover. I suggtes check the next positions...
Hope this helps (remember to rate and comment this).
Dec 16, 2010 | 2000 Mercury Sable
Need diagram/schematics for fuse panel on a 1988 mercury-sable
Ford Taurus/Sable 1986-1995 Repair Information
Fuse Panel and Fuses
Fig. 1: On most vehicles covered by this information, the fuse panel is located to the left of the steering column, attached to the instrument panel
Fig. 2: Fuse panel/block location-Early model Taurus shown
Fig. 3: Location of fuses and the circuits they protect-1995 vehicle shown
More details you can find in autozone.com (free register) with 46 wiring diagrams about Mercury Sable.
Hope helped with this (remember rated this help) Good luck.
Nov 09, 2009 | 1988 Mercury Sable
Both turn signals do not work on 87 mercury sable
The fuse block is usually located on the left side under dash or behind a small cover on that side. If the fuses are ok change the signal relay, after that the signal/light switch on the steering column.
Jul 24, 2009 | 1987 Mercury Sable
This car is a column shifter I HAVE A 1997 MERCURY SABLE, ONE OF THE PROBLEMS IS THAT THE REAR TURN SIGNAL AND HAZARD DON'T WORK, ONLY THE FRONT ONE ARE OK.FUSE IS OK,BULBS ARE OK, TURN SIGNAL FLASHER OK...
the turn signal problem sounds like the multifunction switch (the turn signal switch) is bad as far as the radio and windows it sounds like the trans range sensor is bad it is located on top of the trans at the shift linkage
Jul 07, 2009 | 1997 Mercury Sable
1997 MERCURY SABLE
If you have checked Power/Ground, and alls good look toward the Multi-Function Sw. (turn sig.sw) this is where everything get distributed at...as for your power loss when shifting, is it column/floor shifter ???? need to know....
Need to locate on a 1995 mercury sable where is the turn signal flasher
It is mounted under the dash just above the fuse box.
Jul 15, 2008 | 1995 Mercury Sable
Pro-Fit Pro.Fit Fo 71 02 Ford Explorer/Mercury Mountaineer Sable Logo
136 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
