Question about Acer 22" X223w LCD Monitor
No display power light comes on but monitor will not display.
    President:
  • 1,383 Answers
First open cpu cover then refix RAM memory.
Then power up then press F8 key then enter in enable vga mode go to control panel ->dispaly ->settings change screen resolution to 1024*768 .
If you still not get display check monitor to cpu vga port connection reconnect into it.
Aslo pull out cmos cell for 15 minutes so all bios settings are defaults then check .
you can find cmos cell on motherbord chip set in cpu.
Thanks for using fixya.
Please rate this solution if it helps.
Posted on Jul 24, 2009
Have emachines monitor which is not coming on power button fast flicker
Which power button is flickering (your computer, or your monitor).
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | eMachines Computers & Internet
It display every thing for few second and get off display itself but not power when i switch off on then it come back then again get off
Good luck.
Jul 18, 2014 | Computers & Internet
My microtek 710s monitor won't connect to my graphics card. So, the monitor is VGA and connects to an adapter which changes it to DVI , into my card. Except the monitor won't turn on. And it did yesterday,...
Your monitor is 11 years old. If the power light does not come on make sure the monitor is plugged into an electrical outlet and the power cord is securely connected to the monitor. If the power light still does not come on then you most like have a defective monitor.
If the power light does come on and you are not receiving a display from your computer then try connecting the monitor to another device. If you connect it to another device a receive a display then you know the monitor is good. At that point either the DVI-VGA connector is not compatible with your monitor or there is a problem with your computer.
May 27, 2014 | Computers & Internet
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
Monitor will not come on. power light is flashing
Connect the monitor to any computer having windows operating system. Load to the BIOS screen, if the display comes up, the monitor is ok, the software or the driver software for the monitor has been corrupted, else if no display comes up, the monitor has gone bad.
May 08, 2010 | HP vs19 19" LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
Monitor needs help turning on
Hi prettyhorses, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 18, 2006 | NEC MultiSync LCD1715 17" Flat Panel LCD...
Acer 22" X223w LCD Monitor Logo
201 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
