Question about NAD C320 2-Channel Amplifier
C320 MERCEDES STEERING NOISE
I have a "clicking" noise in my steering column when I start up the engine and it lasts about 1 minute then goes away. It does this every time I start my car. What could be the problem?
There is an electronically controlled valve that controlls the use of petrol vapours from the charcoal cannister \ similar which is mounted to the engine bay by a hard rubber mount.
It is related to the emission control side of things.
This usually operated at the 1st start of the day or after a long period without starting and makes a slight happering sound before going away.
Posted on Oct 14, 2009
    Problem Solver:
  • 6 Answers
This could be a serious problem. Listen real closely the next time your car is started. Is the noise coming from the steering column or the ACTUAL Dash area. Listen closely to see if it is coming from the area where the key is pushed into the ignition. If so!! This could get real bad quickly. There is a unit in there that controls almost everything with the key in the (ON) Position. CHECK AND LISTEN! Also if its not anything like this it could be your (Air Conditioning flaps) They open when the car is turned on to the last known position and something could be stuck in there!
Posted on Sep 07, 2009
1994 Buick LeSabre has clicking noise in steering column when reversing.
Could it be coming from the dash??? That car might be old enough to have a speedo cable. Another thought, I know some Caddys that had an automatic park brake release. You had to put it in gear for the Park brake to release. Hope that helps.
Feb 25, 2016 | 1994 Buick LeSabre
S430 2002 is making noise when steer left or right, but goes away what could it be?
If its a groaning noise and its worse when cold it might be the power steering fluid is low, as the vehicle warms up the level rises and the pump stops sucking air, check the power steering fluid first
Dec 29, 2012 | Mercedes-Benz S-Class Cars & Trucks
2001 chrysler voyager makes loud noise when steering left and right - manual says lubricate steering wheel shaft. How is that done?
the shaft itself cannot be lubricated. at the bottom of the steering column under the dash move the carpet out of the way as much as possilble and look at the rubber boot,spraying somm sylicone lube in there will get rid of a rubbing noise. if it is making a clunking noise when steering look at the tie rods for loosesness. if it clunks when hitting bumps look at the ball joints and more than likely the stabilizer bushings at the lower controlarms and the body where it is attatched are worn out,this is quite common..
Feb 17, 2010 | 2001 Chrysler Voyager
Loud whirring noise at start-up
The first thing to check would be to make sure the power steering reservoir is not running near empty, locate the filler cap for the power steering pump it should be marked and then add the appropriate amount making sure you don't over fill, that may make the sound go away if not we must move on to the next possibility, by the way if the noise gets louder when you turn the steering wheel it is most likely the power steering pump or fluid level is low.
Jul 14, 2009 | 1998 Mitsubishi Galant
MI STEERING COLUMN IS NOT MOVING
There is a rubber dogbone connector that hooks between steering column adjuster and motor mechanism. This piece is broken. It should be replaced by a trained technician due to the complexity of removing part of the underdash panel, steering column, and instrument cluster.
Oct 23, 2008 | 2003 Mercedes-Benz C-Class
2004 V6 cold engine noise related to steering - goes away after few miles
check pawer steering pump belt mybe it is worn out or loose, also check the alteranator belt.
Oct 18, 2008 | 2004 Honda Accord
NAD C320 2-Channel Amplifier Logo
175 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
