SOURCE: replacements belt for DC 17 absolute animal by dyson
Call Dyson....they sent us ours for free along with a new beater bar
SOURCE: How do I dmantle the Cyclone?
You don't! It is not meant to be dismantled. Just pour water inside it. Then let it dry out thoroughly, say, 3 to 4 days, including the filter.
SOURCE: he dyson is making a very loud grinding noise
The belt that rotates the beater bar may be damaged - call the Dyson helpline for troubleshooting and for a solution to the problem.
SOURCE: loud rattle from the front end when engaging the brush
Hi there SmartAlec from NelsonVacuums.com.au here. The rattle is the clutch engaging. It can happen for a couple of reasons. The best case for you is if there is something caught in the brush roller that you can simply remove. The next best is that the end caps of the brush are full of junk that you will be able to remove. Its not easy getting the brush out to clean there but it can be done.
If the brush spins in your hand easily when the brush is removed then it is the clutch itself. THe main roller often melts which is caused when the tension on the belt gets to high thus creating too much heat. THis can be resolved only with a new clutch.
Hope this helps, if you have more questions dont hesitate to reply or if you need parts just visit NelsonVacuums.com.au.
Happy Vacuuming :)
Testimonial: "The feed back was quick and easy to understand. I will definately use this service again"
