Question about Dell Inspiron 2200 Notebook
My laptop won't charge. I have an iGo everything max charger (my third power cord now) and I took it to Radioshack yesterday and they tested the cord and said that it's either the battery or the actual power bit inside the laptop.
  • dmorris70 Jul 24, 2009
    Basic questions that I should have answered in the original post, forgive me.
    The laptop is a Dell Inspiron 2200 from 2005. When I plug the adapter in, neither the battery charging light comes on, nor will the computer switch off of battery power. When I try to take out the battery completely and turn on the computer using just the power cord, it doesn't switch on at all.
  • 30 Answers
How old is the laptop? what make model is the laptop
does the power light turn on "on the laptop" when the power cable is connected
thanks
Posted on Jul 24, 2009
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
Laptop won't charge
Step 1:
If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 12, 2013 | Toshiba Satellite Computers & Internet
My computer says plugged in, not charging
Dead battery. Test battery, try another cord/charger to verify.
Dec 01, 2012 | Toshiba Satellite A135-S4527 Notebook
DELL laptop isnt charging but power cord will keep it on why?
Jenni:
Your battery has died. You'll have to buy another one.
Nov 24, 2012 | Dell Latitude D630 Notebook
Battery won't stay charged
Bring the power cord/charger to a pc shop and have them test it. It might need to be replaced. Otherwise you need to replace the battery.
Jul 21, 2012 | Acer Aspire 55155879 Laptop Charger...
My Inspiron 6000 won't charge the battery.
According to your problem, this may occurs for either the battery of your laptop or the charger is faulty. First check electric outlet where you have plugged your laptop charger is OK. Then check the power cord. If everything OK then you have to change the battery.
Jun 10, 2011 | Dell Inspiron 6000 Notebook
My Hp 6735s laptop won't turn on, I removed the battery and tried to turn it on using the ac cord only, but still the same problem. I can feel electrical charge on the laptop body. kidher
try to test using voltmeter your power cord charger of laptop maybe loose wiring or damage power supply.if same problem need hp service center that's damage motherboard.
May 23, 2011 | Computers & Internet
My Computer Wont Charge!!
if the charger power up your laptop,that means that the charger is working fine,what you need to do is just replaced the battery
Jun 28, 2010 | Lenovo IdeaPad Y510 Notebook
Dell Inspiron 2200 Notebook Logo
1,433 people viewed this question
Alun Cox
